Results 1 to 7 of 7
    Jul 27 2013
    indianapolis/indiana
    will the rs7 blades c7 fit c8 rs6?
    Hello, all jumping into a 2025 RS6, my C7 RS7 has stock blades with dunlop wintersports tires. Will these fit the rs6? Will I need spacers?
    2003 RS6 Apr stage 1 and tiptronic, Apr divertors, Clear bra, Yellow konis SOLD
    2014 S7 Audi exclusive edition 1, Havana black metallic exterior, Havana brown interior, APR stage 1 ECU/TCU, Total Loss Wreck
    2016 RS7 Stage 2, Mythos Black Metallic, SRM/DS1
    2025 RS6 Daytona Grey Pearl, executive package, carbon package, alcantra package, soft close doors, B&O, res delete
    Veteran Member Three Rings KRS Aaron's Avatar
    Jan 25 2011
    Evanston, IL
    What are the specs of those wheels?
    2024 RS6 Performance - Nogaro Blue
    2012 S4 - Nogaro Blue
    2017 Aston Martin V12 Vantage S - Onyx Black
    1994 BMW 850 CSi - Mauritius Blue
    M2 CS Racing
    Jul 27 2013
    275/30R21 99Z 9Jx21 ET35, bolt pattern 5X112, 9 inches wide
    Junior Member One Ring
    Nov 29 2024
    Marin, CA USA
    Definitely not, way narrower than stock C8 width (10.5”) and with a lot more positive offset (face of wheel sits closer to brakes). Would imagine would have significant brake clearance issues.
    Stock wheel is a 21x10.5” ET19. Your C7 wheel specs have the edges of the wheel sitting 35mm (almost 1.5 inches) closer to brakes
    Jul 27 2013
    Quote Originally Posted by whan View Post
    Thank you.
    Jan 25 2011
    Evanston, IL
    Whan is correct. Those are way too narrow and the offset will probably make them run into the brake caliper
    M2 CS Racing
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    The rims will be 22 mm closer to the brake components. If you really liked the rims you could possibly use them for a winter setup. According to wheel-size.com the winter setup uses 8.5 inch rims with a 19 mm offset. I'm not an expert but could you use spacers with the wheels and use them for winters?
