The original equipment manufacturer is finally able to sell these taillights directly and not just through Audi. This allows for substantial savings on these taillights kits:
  • OEM Equipment and Function
  • Proper Rest of World Functionality
  • Complete Coming/Leaving Home Animations
  • Dynamic Sweeping Turn Signals
  • Discrete Orange Turn Signals for Added Safety
  • Eliminates Standard Blinking Brake Light with Turn Signals
  • Missing Rear Fog Light can be Activated with Switch and Additional Wiring
  • No Problematic Coding Dongles or Replacement BCM2 Modules
  • Wiring is Required for Installation - Wiring Components Included
  • VCP (Vag Can Pro) is required for setting proper functionality
  • Packages Available for All Regions
RS6 LED Taillight Package (Highline, OEM) - $1899.00 set (Retail - $2698.00) <-Clink Link for More Information
Information:
Original equipment manufacturer (OEM) European LED highline taillights with discrete sweeping turn signal functionality and coming/leaving home animations. All functions are separated allowing for the orange turn signal to sweep on it's own. The missing rear fog light can be added in along with the needed European headlight switch to make this functional. Taillights are combined with the needed components including replacement taillight trims to allow for a seamless installation for all A6, S6, RS6 and Allroad avant models. Available for all models years including '24+ which are SFD2 protected.
For '19-'23 models Vag Can Pro (VCP) can be included at a discount for in order to set proper taillight parameters. Step-by-step instructions for installation and use of VCP are included. Note that a Windows 7 or newer laptop is required for VCP.
For '24+ models VAS Remote SFD2 Module Parameterization is required - The VAS interface can be purchased or rented for this remote session. If you choose to rent the VAS interface a $300 deposit will be held as an authorization on your payment method until the interface is returned. Once the interface is returned within 15 days from date of departure the $300 deposit will be voided without the need for a refund. Note that VAS rentals are only available within North America.
Questions:
If you have any questions or other needs please post here, PM or email: [email protected]
Thank you,
