Results 1 to 8 of 8
Hybrid View
    Nov 05 2022
    Pennsylvania
    Question 2016 RS7 MMI Screen Issue
    Hey good evening y'all!
    I ran across an issue this morning where my MMI display just went black after driving for a little while. After work, it came back on for a moment and then went black again.
    Wanted to see if anyone had any input of a possible fix outside of being charged an arm and a leg for Audi Service. I asked around a couple groups and someone mentioned the ribbon cable, and I saw something about a power cable. Thanks y'all
    Pull the following from VCDS.
    Code:
    Wednesday,19,February,2025,20:28:16:39021
    VCDS Version: Release 24.7.1 (x64) Running on Windows 11 x64
    www.Ross-Tech.com
                    Address 5F: Information Electr.       Labels: 4G1-035-MIB-HGH2.clb
    Control Module Part Number: 4G1 035 025 F    HW: 4G1 035 025
      Component and/or Version: MU-H-LNS-US   040 0925
               Software Coding: 017563020000000013220002041A00102F000EE5F1700104FE
                Work Shop Code: WSC 02391 785 00200
                  ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115 (AU57)
                           ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
                          VCID: 211CEC36C1406CD2705-8074
    2 Faults Found:
    0020 - Tuner for Satellite Radio
              B11CF 53 [00001001] - Deactivated
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 154
                        Mileage: 220440 km
                        Date: 2025.02.19
                        Time: 19:48:54
                        Voltage terminal 30: 11.6 V
                        Satellite radio tuner status-Satellite radio antenna status: electrically OK
                        Satellite radio tuner status-Channel selection for satellite radio: 0
                        Satellite radio tuner status-Audio Signal: Not available
                        Satellite radio tuner status-Antenna current: 0 mA
                        Satellite radio tuner status-Reception quality: Not available
                        Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                        Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
    6660 - No Communications with Display Unit 1 for Multimedia
              U10E2 00 [00001001] - -
              [Display 1: no signal/communication]
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 154
                        Mileage: 220440 km
                        Date: 2025.02.19
                        Time: 19:47:33
                        Voltage terminal 30: 14.8 V
    Nov 05 2022
    Pennsylvania
    Here is a pull from AutoScan as well
    Code:
    Wednesday,19,February,2025,20:35:11:39021
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
    VCDS Version: 24.7.1.0 (x64)  HEX-V2 CB: 0.4643.4
    Data version: 20240919 DS356.3
    www.Ross-Tech.com
    VIN: WUAW2AFC2GN900118   License Plate:
    Chassis Type: FC-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
              44 46 52 53 55 5F 62 65 6C 6D 72 82 85 8B 8E 8F 90 BA 47
    VIN: WUAW2AFC2GN900118   Mileage: 220468km-136992miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    1B-Active Steering -- Status: OK 0000
    20-High Beam Assist. -- Status: OK 0000
    22-AWD -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    34-Level Control -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: Malfunction 0010
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    82-Head Up Display -- Status: OK 0000
    85-On Board Cam. -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: OK 0000
    8E-Image Processing -- Status: OK 0000
    8F-Pretens. Frt Left -- Status: OK 0000
    90-Pretens. Frt Right -- Status: OK 0000
    BA-Motor Mounts -- Status: Malfunction 0010
    Address 01: Engine (------CWUB)       Labels: Redir Fail!
       Part No SW: 4G0 906 560 G    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H62 0002
       Revision: NCH62---    CVN: 96FDBE6E
       Coding: 1A2A00326546080E3000
       Shop #: WSC 06538 004 1048576
       ASAM Dataset: EV_ECM40TFS0114G0906560G 001002
       ROD: EV_ECM40TFS011_AU57.rod
       VCID: 2C020D02B682B1BAD33-8078
       VINID: 9E546709159309778900004120BBC257CD
    No fault code found.
    Readiness: 0100 1100
    Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
       Part No SW: 4G0 927 158 AP    HW: 0BK 927 156 AM
       Component: 0BK 40TFSIUSA H19 1001
       Revision: --H19---    CVN: 16258E67
       Coding: 000001
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_TCMAL551211 002022
       ROD: EV_TCMAL551211_002_AU48.rod
       VCID: 7CA2FD420662E13A033-8028
    Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V2.clb
       Part No SW: 4G0 907 379 T    HW: 4G0 907 379 T
       Component: ESP9 Premium  H01 0100
       Revision: --------    Serial number: --------------
       Coding: 61BF584B86FD1AD21F00
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ESP9BOSCHAU57X 004018
       ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
       VCID: 42DE43BA240657CA09F-8016
    1 Fault Found:
    36352 - Function Restricted due to Insufficient Voltage
              U1400 00 [00100000] - -
              [HydraulicSupplyUndervoltage]
              Intermittent - Not Confirmed - Tested Since Memory Clear
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 FR    HW: 4H0 907 064 ER
       Component: BCM2 2.0      H36 0560
       Revision: 00002001
       Coding: 0D8A6F4E000000000000
       VCID: 7EA6F74A10FEF32A2D7-802A
       Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
       Component: J764 ELV MLB  H40 0046
       Serial number: 3215000000911011
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-4Z.clb
       Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 26021500040223
       Coding: 680330785D0000
       ASAM Dataset: EV_AirCondiComfoUDS 003008
       ROD: EV_AirCondiComfoUDS_003.rod
       VCID: 6A8ECB1A7CF66F8AE1F-803E
    1 Fault Found:
    0386 - Functional Limitation due to Energy Management
              B10CD 00 [00001000] - -
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 2
                        Reset counter: 194
                        Mileage: 220440 km
                        Date: 2025.02.19
                        Time: 07:10:20
                        Voltage terminal 30: 10.93 V
                        Outside temperature: -5.5 °C
                        Energy management deactivation stage: 1
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
       Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
       Component: BCM1 2.0      H20 0311
       Revision: 21020001    Serial number: 00001008442001
       Coding: 01058011043C9FF2F90048C7A0007800CF9CC308AA0802218000089C710017020060002D0B0000
       Shop #: WSC 12345 123 61029
       VCID: 76B6EF6A38CEBB6A757-8022
       Subsystem 1 - Part No SW: 4G1 955 119     HW: 4G8 955 119   Labels: 1KX-955-119.CLB
       Component: WWS57X 150205  H37 0080
       Serial number:         150210175752
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0002
       Serial number: 23742797
       Coding: 02006E
       Subsystem 3 - Part No SW: 4G0 941 531 AN    HW: 4G0 941 531 AN
       Component: E1 - LDS  H07 0044
       Serial number: 09 02 2015  00000654
       Subsystem 4 - Part No SW: 4G0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z01E32768
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA120043000011406092
       Coding: 020300
       Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Component: AQ_Hum_Sensor  H03 0003
       Serial number: 84584C87000000000001
    Address 13: Auto Dist. Reg (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0053
       Serial number: 00000000000000 Dataset Number: 4G8909863D  0036
       Coding: 7601010101
       Shop #: WSC 12680 002 1048576
       ASAM Dataset: EV_AdaptCruisContrAU57X 002014
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 290CF416B970A492285-807C
    Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
       Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
       Component: Airbag10.43   H62 0086
       Revision: --------    Serial number: 003G0001XG7X Dataset Number: 4G8909602K  0002
       Coding: 303331333131303134334A55304C34473853
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_VW51.rod
       VCID: 343215626EB2E97A8B3-8060
       Seat occupied recognition:
       Subsystem 1 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Component: BF-Gewichtss.  H15 0046
       Serial number: 6940000Y150001AT770R
       Crash sensor for side airbag: driver side:
       Serial number: 3575HRB400S52SLGEHGB
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 3585HRB405733RVK793N
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 3515JRB405J35IMQMGGC
       Passenger side rear thorax airbag crash sensor:
       Serial number: 3525JRB405J35IMK8PB/
       Crash sensor for front airbag: driver side:
       Serial number: 3554VRB4006534046PU1
       Crash sensor for front airbag: front passenger side:
       Serial number: 3564VRB401C531S471E
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Component: Lenks.Modul   H04 0005
       Revision: --------    Serial number: 90372OBP00065
       Coding: 0000FC
       VCID: 3728226E7F440262AE1-8062
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Component: E221 - MFL  H08 0010
       Serial number: 07 02 2015  F0023312
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb-SRI1
       Part No SW: 4G8 920 986 J    HW: 4G8 920 986 J
       Component: TBenUsaAccNv  H07 0043
       Revision: 03001036    Serial number: 658190215596005
       Coding: 0BCF010CBF53D705020500
       Shop #: WSC 16567 006 1048576
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 3FD84A4E57F43A22661-806A
    Address 19: CAN Gateway (J533)       Labels:| 4H0-907-468.clb
       Part No SW: 4G8 907 468     HW: 4G8 907 468
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: 00000001746274 Dataset Number: 4G8909515H  0017
       Coding: 80E1034814
       GVL: FD8FCDCCDCAB680D41040000
       ASAM Dataset: EV_GatewPkoUDS 001024
       ROD: EV_GatewPkoUDS_001_AU57.rod
       VCID: 75B4E8662548B0727CD-8020
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
       Component: J367-BDMHella  H03 8041
       Serial number: 0505495703
    1 Fault Found:
    12291 - Energy Management Active
              U140B 00 [00001000] - -
              [Powermanagement active]
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 194
                        Mileage: 220440 km
                        Date: 2025.02.19
                        Time: 19:50:23
                        Voltage terminal 30: 11.2 V
                        Voltage terminal 15: 11.2 V
                        Control Module temperature: 6 °C
                        System status: Terminal 15 on
                        IN ESP_standstill flag: standstill detected
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status via CAN: On
                        Terminal 15 status: On
                        Datenfeld: 1
    Address 1B: Active Steering (J792)       Labels: None
       Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
       Component: DYNAMIKLENK.  H06 0730
       Revision: 52001005    Serial number: --------------
       Coding: 010000
       VCID: 392C245649501412585-806C
    Address 20: High Beam Assist. (J844)       Labels:. 8K0-857-511.clb
       Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
       Component: FLA           H04 0012
       Revision: AA001002
       Coding: 04018E64747464545425363E00
       VCID: 7CA2FD4206E2E13A033-8028
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H17 0200
       Serial number: 002301150001028 Dataset Number: 4G8909104B  0020
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       ROD: EV_AllWheelDiffeQSPFR.rod
       VCID: 280AF112A27A9D9A37B-807C
    Address 28: HVAC, Rear (E265)       Labels:* 4G0-919-158.clb
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0112
       Serial number: 27021500040473
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
       ROD: EV_ClimaContrUnitRearUDS_003.rod
       VCID: 3D2430465DF8283274D-8068
    Address 34: Level Control (J197)       Labels:. 4G0-907-553.clb
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H19 0783
       Dataset Number: 4G8909553G  0030
       Coding: 008006
       ASAM Dataset: EV_AirSuspe 003025
       ROD: EV_AirSuspe_003_AU64.rod
       VCID: 2F381A0E8794CAA2F61-807A
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Part No SW: 4G8 959 760     HW: 4G8 959 760
       Component: MEM-FS        H03 0157
       Revision: AA000000    Serial number: 00000137099437
       Coding: 00581B0000002001000001010101102030303232203232
       VCID: 77A8E26E3FC4C2626E1-8022
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637 L    HW: 4G0 907 637 G
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E01E3A0 Dataset Number: 4G8909573A  0001
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3728226E7FC40262AE1-8062
    Address 3C: Lane Change (J769)       Labels:| 5Q0-907-566.clb
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H06 0060
       Serial number: 0359707257 Dataset Number: 4G8909535C  0013
       Coding: 040211
       ASAM Dataset: EV_LaneChangAssis 001028
       ROD: EV_LaneChangAssis_AU21.rod
       VCID: 392C245649D01412585-806C
       Lane change assistance control module 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H06 0060
       Serial number: 0360491687
       Coding: 040211
    Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011F5F035E00628002000413
       VCID: 45D458A635A860F22CD-8010
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0009398383 Dataset Number: 4G8909852N  0031
       Coding: 011001010001
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       VCID: 3330167E6BBCEE42929-8066
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0360920290
       Coding: 0126063A20BAF08580B00A80020114000000000000000000000000000000
       Subsystem 1 - Part No SW: 4G0 959 719     HW: 4G0 959 719
       Component: GTO BF  H01 0081
       Serial number: 00000000000000276393
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS40.402  H03 0004
       Serial number: 0000FST00054Z0800000
       Coding: 101F02
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Component: Dachelektroni  H10 0100
       Serial number: 0000000AP00011492909
       Coding: 010000
       Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H11 0029
       Serial number: WA120267000011833829
    1 Fault Found:
    01403 - Glass-Break Sensors; Rear
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 154
                        Mileage: 220427 km
                        Time Indication: 0
                        Date: 2025.02.19
                        Time: 06:55:54
    Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
       Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
       Component: TSG BF        H04 0507
       Coding: 011F5F035E00628002000402
       VCID: 44D245A23E9259FA3B3-8010
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
       Component: EPB-4         H04 0015
       Revision: --------    Serial number: 00000001373582 Dataset Number: 4G8909522D  0007
       ASAM Dataset: EV_ParkiBrake 001028
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D0400068D98B8B2C4D-8078
    Address 55: Headlight Range (J745)       Labels:| 4H4-907-357-V2.clb
       Part No SW: 4H4 907 357 E    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0100
       Revision: --------    Serial number: -------------- Dataset Number: 4G8909865D  0019
       Coding: 057A0A1122600400
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
       ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
       Left LED Headlamp Power Output Stage 1:
       Subsystem 1 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 7560
       Coding: E02000
       Right LED Headlamp Power Output Stage 1:
       Subsystem 2 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 7560
       Coding: E02000
    Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 025 F    HW: 4G1 035 025
       Component: MU-H-LNS-US   040 0925
       Serial number: A278B0FB007324 Dataset Number: 4G9909545B  0018
       Data carrier:
       Subsystem 1 - Part No SW: V03 959 803 AQ    HW: -----------
       Component: NAR 2023/2024  --- 0336
       Serial number: --------------------
       Multimedia system control head:
       Subsystem 2 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
       Component: E380 BDT C7  H20 0250
       Serial number: 90349OBD00182
       Compact disc data bank:
       Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote2---  --- 3006
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 154
                        Mileage: 220440 km
                        Date: 2025.02.19
                        Time: 19:48:54
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 154
                        Mileage: 220440 km
                        Date: 2025.02.19
                        Time: 19:47:33
    Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
       Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
       Component: TSG HL        H03 0507
       Coding: 010F1F024000628002000002
       VCID: 47C852AE0FA472E2DE1-8012
    Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
       Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
       Component: RDKBERU25     H10 0820
       Serial number: 10000000014202 Dataset Number: 4G8909850B  0004
       ASAM Dataset: EV_RDKBERU25 003014
       ROD: EV_RDKBERU25_AU57.rod
       VCID: 2A0E0B1ABC76AF8A21F-807E
    4 Faults Found:
    12652551 - Tire Pressure Monitoring
              C10DC 54 [00001001] - Missing Calibration / Basic Setting
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 154
                        Mileage: 220427 km
                        Date: 2025.02.19
                        Time: 06:56:01
    8397314 - Front Right TPMS Sensor
              C1051 31 [00001001] - No Signal
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 154
                        Mileage: 220443 km
                        Date: 2025.02.19
                        Time: 19:54:59
    8397570 - Rear Left TPMS Sensor
              C1052 31 [00001001] - No Signal
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 154
                        Mileage: 220443 km
                        Date: 2025.02.19
                        Time: 19:54:59
    8397826 - Rear Right TPMS Sensor
              C1053 31 [00001001] - No Signal
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 154
                        Mileage: 220443 km
                        Date: 2025.02.19
                        Time: 19:54:59
    Address 6C: Back-up Cam. (J928)       Labels:* None
       Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
       Component: TopView       H07 0330
       Revision: 11001001    Serial number: 82330JF0207947
       Coding: 0217000101010100000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
       ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
       VCID: 2E06070A809EC3AAFD7-807A
    1 Fault Found:
    9617697 - Function Restricted due to Insufficient Voltage
              U1400 00 [00001000] - -
              [Functional limitation by undervoltage]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 194
                        Mileage: 220440 km
                        Date: 2025.02.19
                        Time: 19:29:05
                        Voltage terminal 30: 7.5 V
                        Terminal 15 status: Terminal 15 on
    Address 6D: Trunk Elect. (----)       Labels:| 7N0-959-107.clb
       Part No SW: 4G8 959 107 T    HW: 4G8 959 107 J
       Component: HDSG-Modul    H14 0049
       Revision: 12014001    Serial number: 034501513 Dataset Number: 4G8909541G  0001
       Coding: 0A3305C122
       ASAM Dataset: EV_HDSGAu573 001022
       ROD: EV_HDSGAu571_AU57.rod
       VCID: 46D65FAA082E6BEA257-8012
    Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
       Component: TSG HR        H03 0507
    Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
       Part No SW: 4G8 919 604 M    HW: 4G8 919 604 M
       Component: HeadUpDisplay H07 0304
       Revision: 00000000    Serial number: 00000000000000
       Coding: C60000
       ASAM Dataset: EV_HUDContiC7 001025
       ROD: EV_HUDContiC7_AU57.rod
    Address 8B: Adaptive Cruise 2 (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7601010101
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 2708F22EAF6492E23E1-8072
    5 Faults Found:
    38400 - Function Restricted due to Missing Message(s)
              U1111 00 [00010000] - -
              [FAULT_CIM_TIMEOUT_AAG]
              Intermittent - Not Confirmed - Not Tested Since Memory Clear
    57600 - Function Restriction due to Implausible Message(s)
              U1112 00 [00010000] - -
              [FAULT_CIM_ALVAAG_FAIL]
    99584 - Function Restriction due to Implausible Message(s)
              [FAULT_CIS_AAG_STOPLIGHTS_PLAUS_FAIL]
    144640 - Function Restriction due to Faults in Other Modules
              U1113 00 [00010000] - -
              [FAULT_CIS_STPL_AAG_FAIL]
    156672 - Internal Control Module Memory Check Sum Error
              B2000 00 [00010000] - -
              [FAULT_EDC_ECU_DEFECT]
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145 B    HW: 4H0 907 145
       Component: AEM - LEAR    H09 0008
       Revision: 00001001    Serial number: 97811004771902 Dataset Number: 4G8909578B  0013
       ASAM Dataset: EV_AEMLearAU64X 002016
       ROD: EV_AEMLearAU64X_AU57.rod
    1 Fault Found:
    1294 - Actuator 1 for Drivetrain Mounts
              C1131 07 [00001001] - Mechanical Failure
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 154
                        Mileage: 220427 km
                        Date: 2025.02.19
                        Time: 06:56:12
    End----------(Elapsed Time: 02:54, VBatt start/end: 14.7V/14.7V)-----------
    Established Member Two Rings NorthernGTI's Avatar
    Oct 19 2024
    C7 TDI
    Mississauga, Canada
    Common problem. Many DIY videos on youtube. I dealt with the same issue(cable chaffed) causing mine to not even open. Fixed cable, same issue. Had to reset MMI control module(below MMI screen) and havent had the issue since.
    2014 TDI
    Apr 18 2016
    2016 RS7 Prestige
    Boston Area
    Way too many additional malfunctions beyond infotainment. Suggest first checking the battery. Failing battery will cause all those codes. Just a thought.
    2016 RS7 / Mythos Black / Comfort Seats / B&O / Layered Alum Trim
    Also in the stable:
    - 2018 GMC Sierra (Daily)
    - 2020 Kia Telluride SX-P (Daily)
    Past: S7, A7, A8, Multiple A6's
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Quote Originally Posted by BasicBlack View Post
    I like this suggestion! Start simple. Check the battery, though you may have multiple issues here... Looks like you have a bad motor mount too
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Established Member Two Rings STXA7's Avatar
    May 24 2024
    Shelves full of crap
    South Texas
    what might be happening is the mmi unit thinking it has retracted, thus shutting off the light. try pressing the back button or retract button. the plastic gear wheels are known to break wimpy internal mechanicals
    I am a 034 nutswinger
    Disclaimer: I am not sponsored or affiliated with 034 motorsport, just one of many happy customers.
    May 03 2024
    Duluth MN
    Quote Originally Posted by NorthernGTI View Post
    How did you reset the control module below?
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    0386 - Functional Limitation due to Energy Management Voltage terminal 30: 10.93 V
    His scan literally proves his battery is a problem. While it may not be the problem causing his MMI retraction issue, it is still a problem.
    Oh, and you need a new motor mount, Mount 1 is toast.
    18 S6
