Howdy Folks,
I've spent the past few days reading through this forum assisting the troubleshooting of my sons 2005 Audi S4 (Unsure if its a B6 or a B7). Its a 4.2L V8 petrol engine.
He's been having issues starting the car, replaced a fuel pump thinking that was the issue. 3 weeks prior the starter motor stopped so that was replaced. I dont think they are related, but I'm mentioning it just in case it might be...
After replacing the fuel pump, he's been needing to use a portable jump starter to start the car. We have had his car battery tested though and it is fine (although after this weekends troubsleshooting the voltage is low - its at 12.1V now and my battery charger just died on us.. Ugh).
Having to use a jump starter, makes me think he's got an electrical issue and not a mechanical issue.
Today I pulled the ECU out - it has power on pin 62, but the resistance is high (my multimeter reads 1.9 - is that Ohms?). The earth seems strong - its measuring 0.003 resistance. So I suspect the issue we have is not enough current getting to the ECU due to high resistance on the positive line.
On pin 62 - When the key is off power reads at 11.11V, when the key is on, Power reads at 11.5V. Remember the battery is currently at 12.1V - so we have voltage drop of .6V at least - I'm not sure why there is a change when the key turns on?
When the key turns on, all the dash lights cycle except the Check Engine Light. Which further makes me suspect the ECU over the other items I've learnt about from this and other forums.
Going by the pointers in this thread:
https://www.audizine.com/forum/showt...t=check+engine
Fuses are all good. I too can force the fuel if I jumper the relay..
I dont have a scanner - so I'm wondering where to go from here (other than to replace my broken batter charger). Is it logical to jump a 12V+ directly from the battery to pin 62 for the ECU? Is there a logical point in the wiring to investigate this high resistance?
Or, is it that a non issue and its likely the the crank sensors could be impacting the CEL?
Or is now the time to replace the ECU?
Or is this the kind of job that just needs a scanner - and if thats the case - what is the best scanner to go for? Is an ELM 327 reasonable?
Sorry tfor the shotgun approach & thanks in advance for guidance.
