Results 1 to 12 of 12
    Senior Member Two Rings cb s4's Avatar
    May 11 2013
    ct
    Dash board removal
    Whats the best write up or video for removing the dash board.mine is warped and I also have to do the heater core.
    Senior Member Two Rings eurogz's Avatar
    Apr 02 2021
    SE PA
    https://www.audiworld.com/tech/int54.shtml
    I have a spare dash laying here if you need one
    Oct 14 2006
    by the lakeshore, mi
    Quote Originally Posted by cb s4 View Post
    I highly recommend getting an all metal heater core unit. I did a heater core job a few months ago. Wasn't a terrible job. I read through diy posts and watched many videos before I did my heater core job which helped a ton. One thing you DON'T need to do is remove any of the relay/wiring panels, the ones on either end of the vehicle.
    Current: 01 A4QM avant daily driver.
    Past: 92 ABZ 100CSQM avant, 97 A6Q avant, 93 S4, 95.5 avant, 93 S4, 91 10vt CQ, 98.5 SC'd & IC'd A4QM sedan.
    May 11 2013
    ct
    Do you have any link for the one you got? And every video I watched i feel like they unplugged everything to do the job
    Oct 14 2006
    This is the heater core that I bought. Here are a couple of videos I used as guides one and two. Like I said before. I watched multiple different videos of this job (like 10). Only remove what you need to. When I finished my heater core job, I didn't have any forgotten parts/bolts/nuts left. The only things that I had leftover were broken plastic bits.
    Junior Member Two Rings Glennb's Avatar
    Sep 27 2015
    2020 V6 Tacoma
    I’ve heard it just about the most terrible job on the b5. I’m thinking I also have to do a.new heater core soon.
    May 11 2013
    ct
    Thanks i Appreciate the help
    Aug 07 2022
    Eagle, Co
    If you’re thinking you need to replace the heater core because you don’t have heat, I highly recommend flushing it with CLR first. I have had total success with this method. Of course if it’s leaking that’s a different story.
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by Glennb View Post
    It’s not that bad if you pull the whole dash out as one piece. Can easily be done in a day first time doing it. This is the video I followed
    https://m.youtube.com/watch?v=J40bce...N5IHdheQ%3D%3D
    Oct 14 2006
    Quote Originally Posted by Hmh800 View Post
    Unless your core is super clogged. I tried flushing mine without much success. So before this winter I said eff it and replaced the heater core as didn't want to drive in the winter again without heat. When I got the my old core out, I poured out the coolant and had very little come out, probably 2 ounces if that.
    May 11 2013
    ct
    Any write ups on how to get the dash cover off of the dash board? Trying to replace it and stuck
    Oct 14 2006
    Quote Originally Posted by eurogz View Post
    eurogz posted this write up a few days ago.
