before reassembly, i decided to test my knock sensors per the service manual. this was mostly out of curiosity since they weren't throwing any codes, though i didn't get a chance to pull DTCs before removing the engine.
the manual says to measure pins 1 & 2 (next to the connector tab) for "infinite" resistance, and anything else is a fail. OK, pretty simple...
all of mine measure around 4.9 megohms with a quality multimeter (Ideal 61-486, 40 megohm max range). i even tried torquing one to the block because they're piezo devices, but that didn't change the resistance value. the testing procedure doesn't specify anything about temperature or other conditions.
these probably weren't bad since it wasn't throwing codes; monitoring knock sensors is a huge part of the ECU's job, so it would know. could 4.9 Mohm indicate incipient failure? or, since they all show they same value, is 4.9 Mohm actually fine and maybe Audi equipment measures a smaller range that would show megohms as infinite?
bottom line, i'm not sure whether to replace them. if i don't, at least it's just service position and removing the IM to get to them.
- emilio
