    Feb 11 2025
    PCV/Water Pump/Thermostat/B12 Pro Kit install
    ‘14 3.0t Q5
    I’m currently collecting parts for some maintenance under the Turbo and replacing the tired shocks and lowering it a touch. I have a couple questions and wanted to know if there was anything else I should replace while I’m in there. I purchased the “breather kit” from FCP Euro and I just noticed that the seal kit for the injectors weren’t OEM. The maker is Elring. Should I pony up and buy OEM, or will this kit suffice? I’ll be doing a Walnut blast and injector decarb, changing out the pcv, water pump, thermostat, changing the gasket on the oil filter, the breather hose, pcv hose and intake manifold gaskets. I’m going to wait on changing the belts because I’m going to get it tuned and haven’t decided if I’m going to change out the crank pulley, or just keep it stage 1. Is there anything else I should replace?
    For the rear coil install, I’ve seen a three or four different ways to go about removing the coil. I went with an inner coil compressor and I’m thinking that I’ll unbolt the sub frame, leaving a few threads bolted in, giving me a little more room to get the spring out. There was another video where they lowered the control arm after marking the bolts and slowly lowered the control arm with a floor jack… I’m thinking this method with the addition of using a spring compressor to hold the spring in its compressed form, so the lower control arm isn’t loaded, might best a better option though. Is there a method that you found safest?
    Thank you in advance!
    A couple links for reference.
    https://www.audizine.com/forum/showthread.php/491209-Rear-spring-removal-DIY
    https://youtu.be/sKkVugt6w_w?feature=shared
    https://www.fcpeuro.com/products/audi-crankcase-breather-kit-06e103547hkt
    1 PCV Valve Hose VAG-06E103213
    1 Engine Air Intake Hose ClampVAG-N10203601
    6 Engine Intake Manifold Gasket ELR-217330
    6 Engine Intake Manifold Gasket ELR-225170
    1 Engine Coolant Pipe O-Ring VAG-N90316802
    1 Engine Crankcase Breather Hose VNE-4008346
    1 Engine Crankcase Vent Valve OES06E103547AH
    6 Fuel Injector Seal Kit ELR-933140
    1 Engine Coolant / Antifreeze ZER-861526
    Feb 11 2025
    Bump
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Not certain about the injector seal kit. I haven't pulled them out. Search around the supercharged 3.0T engine is used is several models.
    For a 2014 you might as well change the supercharger oil, (maybe intercooler bricks too), spark plugs, and have extra oil + filter on hand incase any coolant drips into the valley when removing the pcv which is likely. I'm in the middle of this job now. FCP has great step by step guides.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Also buy the 034 metal supercharger bleeder screws because the oem plastic ones are trash.
    Senior Member Three Rings 2008s4's Avatar
    Oct 28 2016
    Central, CT
    Quote Originally Posted by q5 dave View Post
    ECS has their own now too. Glad there’s choices for that crap OEM plastic
    2008 S4 Brilliant Red (sold) | 2008 RS4 Daytona Grey (sold)
    2008 A4 2.0 Avant (sold) | 2016 S4 Misano Red (sold)
    2014 MB E63s Wagon Eurocharged | 2015 Q5 3.0 034 Stg 1
