Results 1 to 2 of 2
    Jan 15 2020
    Sofia, Bulgaria
    Question P1398 - Engine Speed Signal - Short to Ground
    Hello all,
    I got this error recently - P1398 - Engine Speed Signal - Short to Ground.
    After clearing, the error appears again.
    The engine code is CTGE and it is running absolutely fine. The engine is equipped with МТМ M-Cantronic.
    Where is this RPM sensor located?
    What how to check if the sensor, connector and wiring harness are the problem?
    Could this error be related to the MTM M-Centronic upgrade?
    Any help would be highly appreciated!
    Address BA: Motor Mounts Labels: 4H0-907-145.clb
    Control Module Part Number: 4H0 907 145 B HW: 4H0 907 145
    Component and/or Version: AEM - LEAR H10 0008
    Software Coding:
    Work Shop Code:
    ASAM Dataset: EV_AEMLearAU64X 002016 (AU57)
    ROD: EV_AEMLearAU64X_AU57.rod
    VCID: 280E2098C2799C4A37B-807C
    1 Fault Found:
    0328 - Engine Speed Signal; TD
    P1398 00 [00001001] - Short to Ground
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 116
    Mileage: 68080 km
    Date: 2025.02.10
    Time: 16:01:04
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    I would definitely remove the cantronic and see if theres still an issue
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
