Results 1 to 4 of 4
Thread: 8y Dash rattle
    Sep 28 2019
    22 RS3
    Arkansas
    8y Dash rattle
    Anybody have it, sounds like it's coming from somewhere behind my gauge cluster(screen). Also, strangely, it gets quieter as the car heats up. It's so loud and annoying. I know someone said he had a rattle from his hud.
    Established Member Two Rings Nando7057's Avatar
    Nov 13 2022
    '02 Camry
    NC
    I had a similar rattle. I thought it was the HUD surround which I took off and used some felt and tessa tape to snug up the fit.
    The rattle ended up being the knee panel beneath the steering wheel. The plastic guide pins rub against the frame of the dash. The noise disappeared when the weather warmed up but came right back when it got cold.
    Take the panel down and use some sort of felt or tessa tape to wrap the plastic guide pins. Problem solved.
    2024 RS3 Kyalami Green
    Carbon Pack| RS Tech| Black Optics & Roof |Micromata Stitching |Xpel Tint, PPF & Ceramic Coating | Blackvue 900x & Blendmount | IDCarParts | Carbon Fabrik
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    Quote Originally Posted by theverge View Post
    I have a nasty rattle but on the back tray area. I brought it to the dealer and they couldn't find it but my advise to you is to bring it to the dealer the sooner the better because I was told that noises like that are only covered for the first 12 months.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Jan 03 2023
    south carolina
    following. have the same issue
