If you see a red post number next to it, it's covered and listed. If not, I just haven't gotten to it yet. I'll also include a direct link where I purchased for the companies I've chosen to support, if one is available.
Vehicle Mod list/Glossary if specifically already covered
1. Custom Procharger kit designed and built by me (VAST AZ) utilizing a Procharger D-1SC head unit, including 2.7l Bi Turbo intake Manifold Conversion
Got the head unit from Bob @ Brute Speed. He's very helpful
https://shop.brutespeed.com/ati-pc05...ati-pc051a-001
2. 1,500hp Air to Water intercooler, built by Shearer Fabrications. Post 34
https://shearerfabrications.com/prod...92b39910&_ss=c
3. 5 gallon water/Ice box, built by Shearer Fabrications.
https://shearerfabrications.com/products/sf06-04010
4. Fueling from Deatschwerks with a brushless 440 pump/PWM controller, with their programmable dual pump voltage booster. It is fed by a factory fuel pump.
https://deatschwerks.com/products/9-441-c103-0900
https://deatschwerks.com/products/4-00-vb40ax2
5. Radium Engineering Surge Tank with integrated fuel pressure regulator.
https://www.radiumauto.com/FSTR-RA-F...ted-P2768.aspx
6. 034 Motorsport Lightweight Brake rotors Post 16
7. 034 Motorsport Billet engine mounts
8. 034 Motorsport transmission mounts
9. Single 4" Aluminum Exhaust with 3" downpipes built by me Post 8
10. VAST AZ custom headers with integrated individual EGT sensors
11. QA1 rear shocks, dual adjustable Post 25
12. 034 Motorsport suspension coils
13. 034 Motorsport front suspension arm kit with Adjustable upper arms
14. VAST AZ forged beadlock wheels (17x9) with 275/40/17 Hoosier DR2 Post 9
15. JXB Center Driveshaft Support
16. JXB Wavetrac Rear Differential
17. ZF8 conversion
18. 034 Motorsport Camshaft kit
19. VAST AZ ported heads
20. 3.2l stroker engine utilizing OTS Diamond Audi R8 pistons
21. ECU contol provided by Syvecs OEX running alongside the factory computer
https://www.syvecs.com/product/syvecs-oex/
22. CAN integrated Individual EGT sensors from ECU Master
https://ecumasterusa.com/products/ec...BoChWEQAvD_BwE
23. EGT Sensors from The Sensor Connection
https://thesensorconnection.com/prod...diameter?v=535
24. Custom Aluminum Radiator meant for a Ford with both hose connections on drivers side
25. Divorced transmission coolant lines from radiator, with external cooler
26. Deleted factory oil filter and cooler. Used VAST AZ oil cooler/oil filter delete and Relocated new filter unit to drivers side "frame rail"
https://motionraceworks.com/products...ont-load-5-901
27. Motion Raceworks catch can
https://motionraceworks.com/products...can-dual-10-an
29. 8 rib pulley conversion to accomodate the standard procharger Post 27
30. Lightweight Group 48 Lithium battery Post 30
I'll add details as I go....
Latest 2 video uploads on the subject
If it's a "short", sometimes it won't let me embed it. Click the link if one is present.
https://www.youtube.com/shorts/ZiHFbksGtbc
What's up Audizine! Let me introduce myself. I'm Rockcandy, Marshall, or VAST AZ depending on where you know me from. Welcome to project "Sequel"! I like to tell stories, so I'm going to give you a little history before diving into the current status of my 2015 Audi S4. I've always been a B5 guy before this car. In fact, I've probably had a dozen of them sprinkled with a C6 RS6 and some plain old A6's and a Q7 on top. My history goes fairly far back with Audi's, as I was working on B5 S4's in the dealer since they were still under warranty. Ahhhhhhh yes, the good ol days. I remember swearing them off back then. Telling myself someone would have to be an absolute idiot to own one of those piles of junk. My days were filled with engine reseals, motor mounts, axle seals, cv boots, and suspension bushings. The hours were good, but because of this, the B5 just always seemed like a piece of junk to me. Then one day, a customer traded one in with "blown turbos" and I got a screaming deal on it as a tech, since the dealer didn't want to fix it. That's when the bug REALLY hit me.
It was bone stock, minus the stage 2 tune that the original owner had put on there. After fixing it up back to driver status, the mods quickly started flowing in. Back then, K04 turbos were the bees knees and everyone wanted AWE stuff on their B5. The car instantly turned into my wife's daily driver while I kept on driving my Jeep. That's a totally different addiction I had. I pretty much ran through the typical catalog of mods from RS6 turbos, to H&r/bilstein suspension, wheels, methanol, cosmetics, interior swap, B7 RS4 brakes etc etc etc. As the years wore on, my wife drove the wheels off of it, including racing on Friday nights and even raced it on Pinks All Out for you old timers that remember that show. She popped a trans a few days before the race and I slammed in our spare, which had a very difficult to access second gear. :( So the show was a flop, but she had a ton of fun doing it and our Friday nights. Our only son at the time really solidified his racing spirit throughout all of it. He was probably only 3 by this point. Fast forward to today and he has his own B5 S4 avant with K04 turbos and all the fixins!
That was kind of life. Pretty easy going and full of "time" to do what we wanted. Though we always said "we are so busy". Just like many of you, no doubt.
- - - Updated - - -
- - - Updated - - -
