Results 1 to 4 of 4
    Feb 08 2025
    WI
    crankshaft position sensor
    Anyone have a write up or tips on changing the crankshaft position sensor ?
    Feb 08 2025
    WI
    I ended up:
    1.Dropping Half shaft T10 star bit. (just the inside) That allowed more room to work on the sensor
    2. Removing Axle Heat shield.
    3. removing sensor heat shield T25
    4. unplugging sensor
    5. removing T25 bolt holding the sensor and aluminum spacer it’s pressed into.
    6. remove faulty sensor from spacer and press in new sensor
    7. Repeat in reverse to complete
    nice, what were the car's symptoms and did changing it solve your problem?
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    *only use OEM
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
