Results 1 to 5 of 5
    Junior Member One Ring
    Dec 31 2023
    Minnesota
    Front left headlight signal issue
    All other blinkers work, but when using left turn signal, it blinks quicker, and the bulb for the drl (yellow), works but then turns off when using blinker, but then turns back on again in the opposite rhythm of the regular blinker, any reasons why?
    May 10 2018
    MA
    B5’s don’t have drl
    Nov 13 2009
    Victoria, B.C., Canada
    I think he means running lights.
    Have you tried swapping the bulb out? Sounds like one of the dual filaments is burnt out.
    Dec 31 2023
    Minnesota
    Sorry yea, meant to say the running lights, not drl’s, I swapped the bulb out and that new bulb didn’t work at all, it was one I had sitting around so I might just need to order a new one and see
    Nov 13 2009
    You can also swap it with the other side that is a known good bulb and see if that fixes it. If it doesn’t work then check for corrosion at the plug and test for voltage.
