Results 1 to 9 of 9
Thread: Tip-6MT
    May 04 2023
    Minnesota
    Tip-6MT
    i’ve dove through other forums unable to get some for sure answers. pretty elementary on the subject still… what part numbers 01e and 0A3 trans bolt directly to the 2.0T. do some take more mounting fabrication than others? anything helps thank you.
    Senior Member Three Rings a.four's Avatar
    Jun 09 2019
    2023 Jeep Wrangler
    I’ve just had an 01E conversion done, I used a kit from Audis4parts.com. Took 3 different driveshafts to get the right length, I think the correct length was 64.25. Other than that the kit had everything I needed aside from wiring instructions.
    May 04 2023
    Minnesota
    Quote Originally Posted by a.four View Post
    seems like a nice kit but i’m budget as they come and i feel like i could for sure source my parts for almost half the price. willing to go through trial and error and more labor than just pay up. college is expensive :/
    Mainly i was asking what transmissions do and do not fit. as long as it says 01e or 0A3 it’ll mate the motor?
    Jun 09 2019
    2023 Jeep Wrangler
    Quote Originally Posted by brzdy View Post
    I would use the kit contents list as a guide, if you choose to go 01E. I’m not certain which bolt up/which do not.
    May 20 2010
    Any reason not to go with an 02X?
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    May 04 2023
    Minnesota
    nope, unless i can’t find one, i have noticed many 0A3s in my area however.
    Sep 16 2010
    Central Wash
    Can I ask possible dumb question-- I've done swaps on other VAG cars / Audis- why do I see many people saying you need a 'tune' for a manual swap? Some people even sell the ECU with the swap.
    Whats going on here....Can you NOT code the ECU / ABS to manual?
    Senior Member Two Rings frogspit's Avatar
    Jul 15 2017
    CA
    Quote Originally Posted by rollerton View Post
    Yes you can do it all through VCDS
    Check this thread
    https://www.audizine.com/forum/showthread.php?t=460049
    GTX2863R Motoza Tuned E85 17psi
    Sep 16 2010
    Central Wash
    Quote Originally Posted by frogspit View Post
    Check this thread
    Oh yeah, there it is...same as every swa before it.
    I still don't know why I aways see people talking about sending the ECU in for a 'tune' during swap or what that's all about.
