Results 1 to 14 of 14
    Starter job replacement bolts
    I think the s4 and rs4 starters are the same for the era. I'm doing for 07 rs4, using a valeo starter.
    A few good videos for starter replacement, but nowhere online has the part numbers for the torque to yield bolts that need to be replaced during this job (Think they are for the engine mount bracket?).
    So please, any info on how many tty bolts need to be replaced (Think was three, maybe two) and part #
    Dealer diagram was not clear and parts people at dealer not helpful to figure out.
    Thanks all
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    Do you see what you’re after here?
    Once I take apart I might know. This is the same diagram that the dealer wasn't able to tell me which are one-time use.
    My guess was bolt 25, get a few of them so I can get on with it and not have to make an order mid job.
    Maybe the replacement bolts are some number 3's? don't think it is those
    I've heard over the years from various sources about, "the bolts that should be replaced during the starter job"
    Maybe it is not that important to replace bolts? Although I've had bolts that look healthy snap on this car on reinstall so kind of...don't want to get stuck on jackstands with snapped bolts being re-used
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    you’re going to rip out the threads in your block or bell housing wayyyy before you snap one of those bolts. They’re not like those aluminum bolts allover the newer audis.
    edit: just reread this and realized you’re not talking about starter bolts but rather about mounting bracket to subframe/chassis bolts. Yeah you should replace those, but it’s not the end of the world if you don’t. just when you go torque+extra turn, do about half the turn specified. You can always replace them next time you’re under the car.
    I have subframe to chassis bolts on one of my cars that are 20 years old and have been reused over a dozen times.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Veteran Member Four Rings Rol-co's Avatar
    Dec 12 2020
    Europe (NL)
    I never replace bolts in that area, just re-use.
    Only milk and juice come in two liters, "05 S4 B7 tipt Avant phantomschwarz/schwarz
    Senior Member Two Rings bennyc767's Avatar
    Mar 31 2009
    An Old Avant
    The Big Sky
    I came by this a while back, it shows the bolts that are recommended to change (S4): http://sandbox.enjoybeing.net/diy/S4/starter/
    Thanks all, will update if the starter itself was my intermittent starter fix
    May 10 2016
    Southeastern PA
    Quote Originally Posted by longlivenacars View Post
    If your car struggles to start sometimes in the cold then replacing the starter should fix the issue. It completely eliminated the issue for me.
    Agree, it does it when warm in summer too
    Dec 12 2020
    Europe (NL)
    Quote Originally Posted by bennyc767 View Post
    Not the best one,
    No need to take out the down pipe, just intake hose at the top for that reverse bolt.
    Replace engine mounts at 50k? If they are not leaking or trow a code they are fine, leave them alone. Easy to replace afterwards if needed.
    Its a lousy job to replace the starter but so rewarding if done. 😁
    May 10 2016
    Southeastern PA
    Quote Originally Posted by Rol-co View Post
    I agree. I remember questioning whether or not I still liked working on cars when I was doing this job. I know at least one of the bolts that hold the heat shield on was almost impossible to access. I was very rewarding though once the job was complete.
    This really is one of those jobs
    The connector on the solenoid seems to have a stopper for the thicker (ground wire?) right beside it. Haven't been able to slide a pick under or undo the tab, looks so brittle it is broken to press down on it. I looked with mirror and flashlight and it looks like a different type of connector ((almost like it has metal embedded in the plastic). MY hope was to lean the starter down (everything else is disconnected from it) and then undo the connector. Bolts are out/off for starter but starter is very stuck. Took a break so I don't smash it.
    So, very stuck , seemingly original to car starter; what are best methods to loosen it?
    What should I do about the removing the electrical connector? obv trying to preserve it for reinstall
    May 10 2016
    Southeastern PA
    I'm 99% certain I broke that connector when I disconnected it. I think I wrapped it with that self adhering silicone tape once I installed the new starter to keep it from wriggling off. I was PISSED when the plastic broke. I think it was the little tab that keeps it locked in place; not the entire housing.
    Thanks, alright then, will take another go at it
