Results 1 to 15 of 15
    May 20 2010
    Fan Control Module?
    My battery went dead because I accidentally left the heated seat on while it was on accessory and I was listening to music at my storage unit. I've subsequently had to jump the car a few times and she started right up each time.
    Well the other night, I tried to do the same thing and then a bunch of smoke came from the front left of the car, down low. The only electrically-related thing down there I can think of was the fan control module. Has anyone seen this happen to theirs? Or is there something else down there I should investigate when I get to doing this?
    I'm leery of trying to even start the car again for fear of an actual fire. I can probably disconnect it up top before swapping batteries to start it.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Portland, OR
    Is this on the RS6 or one of the Allroads?
    I’d immediately suspect the fan control module, too. There isn’t really anything over there aside from that or maybe the fan itself. And as far as I can tell they’re all interchangeable so sourcing a new used one shouldn’t be too difficult. I’m sure there’ll be some evidence of melting if you saw smoke.
    May 20 2010
    Allroad. Thanks. I am just amazed because I wasn't even trying to start the car at that point--it was just connected to power and the unit started smoking. I can steal one off my other Allroad, thankfully, but this just seems unusual--it's too cold for the fans to come on, unless the low rad hose fan switch is bad too.
    Feb 05 2007
    Portland, OR
    During my cleaning adventures on my Allroad I tried to disconnect my fan control module and the connector was impacted with road debris and caked oil so I actually broke the connector trying to get it out. At that point I decided to clean it in place as best as possible and move along. With that said, I wonder if you've got water ingress or something shorting out the module and when it got power it got really angry? It is that time of year.
    May 20 2010
    Anything's possible. There is def oil caked up in that area so I would hope that protects it from water, but makes sense if there is a short because I had charged the battery before and it went dead quick enough.
    I probably won't get time until next week at the earliest to look at it, with the weather predictions of rain and mixed rain/snow/sleet.
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    they do die. $50 amazon chinese replacement seems to be working OK. Hurry before they get expensive :)
    https://www.amazon.com/dp/B07MZV3K42
    too late, already expensive
    May 20 2010
    Quote Originally Posted by V1nny View Post
    $65 isn't too bad. But yeah it was def the FCM. Shorted internally so when power was applied, it would just heat up like no tomorrow, hence the smoke. No smoke after disconnecting it, but I haven't actually run the car. Will do that to raise the height when it's time to change it.
    Dec 04 2012
    Arlington VA
    I would not drive like that. It may also kill your battery, due to big current drain, which will be more than $65.
    May 20 2010
    Oh, I am not going to drive. I was thinking of idling long enough to raise up the suspension before shutting it off. It's disconnected so no current is going to it.
    Feb 05 2007
    Portland, OR
    Yikes. That concerning! You may want to inspect the harness for any damage, too.
    I’m glad your car didn’t catch on fire! I’m curious what the mechanism of the failure was, though. I don’t want to suffer a similar fate. I do know both my 2.7’s the FCM is/was bathed in a nice layer of oily grime.
    May 20 2010
    Probably moisture and corrosion but I won't know more until I do take it off. The lighter brownish on the outside of the connector remind me of coolant/water and oil mix. Could be a leak I didn't notice before.
    This car spent the majority of its life since 2010ish (IIRC) in Indiana, and also did frequent trips to Mass and back. So much of its life in the salt belt, and at >265k, zero surprises anymore haha.
    I'll have to fix the connector too--it's got that welded piece in it.
    Dec 04 2012
    Arlington VA
    these modules, particularly cheap ones, are not super watertight, so eliminating any leaks around it would be helpful.
    May 20 2010
    Anyone know what the name/part # of the black power connector into the FCM? I think I'm going to splice a new one on considering the melting. I keep finding smaller, 4-pin vs the 2 blade ones in my searches
    Established Member Two Rings LZ9ROAD's Avatar
    Feb 13 2019
    mars
    4B0 971 955
    Hope this helps, this is the large 2 pin connector.
    95' M3 (stock), 04' A6 (Wagner, RS6 Turbos, Stock Motor, 6 Speed Swap, ETC)
    May 20 2010
    Quote Originally Posted by LZ9ROAD View Post
    4B0 971 955
    Awesome! Thanks! I might have a source on getting part of the harness and connector. This is great to have in case.
