Results 1 to 3 of 3
    Junior Member Two Rings
    Sep 10 2020
    Phoenix area
    No DTC's but 2 Readiness won't come ready, OBD 11 diagnostics shows tank leaks.
    I have been struggling with finding what my issues are caused by. I failed emissions as 2 of my Readiness monitors won't come ready. I can see using the OBDEleven scan tool which 2 they are: Monitoring of Air Injection and Monitoring of Tank ventilation. It should be noted I did swap out the engine late last summer and aside from having to replace the battery as it sat a very long time, it's been running fine since with no codes. When I say no codes, I mean, yes, a few oops, I didn't plug this in or tighten this hose up codes, but I cleared them and aside from having to replace the battery as it sat a very long time, it ran fine. So I know the system is able to read faults as not only were therre initial faults after swapping the motor, but I did get one or 2 since then. I have put about 12000-1500 miles on it since the the engine swap. I have put about 12000-1500 miles on it since then. So having only owned this car since November 2022, it passed the first emissions, but my 2 year mark was this November and that is when I failed. So as far as I know, I have had this issue since swapping the engine. The car runs fine and I have no DTC's, and yes, the light works. So I researched a bit and found it's possible I have weak OO2 sensors can cause this, but not weak enough to flag a DTC. In my case I was lead to replacing the 2 Upstream (pre-cat) ones. This didn't help. Further diagnostics with the OBDEleven I ran tests and I am getting some errors related to tank leaks. But why no codes?
    Here are the screenshots of the OBDEleven tests and scans. Any ideas on what would need repair/replacement?
    Oct 20 2021
    Tank leak messages would lead me to believe it could be vapor canister issue or something. Do you have access to VAGCOM? I found this: https://www.ross-tech.com/vag-com/m_blocks/070-079.html
    2021 SQ8 | Orca Black | 42K Miles
    Sep 10 2020
    Phoenix area
    Quote Originally Posted by CYANiD3 View Post
    This was scanned with OBDEleven, a phone app tool with a lot of the same features as VAGCOM/VCDS, a bit dumbed down tough. I have looked into getting VAG, but I don't see what interface is available for the 2017/4M model Q7. I have a friend who has it that I used many times on older VW's but it won't interface with my Audi's newer system.
