Tuesday,04,February,2025,18:44:15:15886
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240919 DS356.3
https://urldefense.com/v3/__http://www.Ross-Tech.com__;!!AICBUC8eM8hH!lKV_O5u_E2bm3r1CaJ8TfbJ4 t5eyD9f76Ga06kVjgX2kr_pt8MWjs2GNMVjx5mmq0LVfY_XmtD 8zxA0ooPzYICKs$
VIN: WAUVVAFR3AA056056 License Plate: GOONGIT
Mileage: 187260km-116357mi Repair Order: 0002
Chassis Type: FR-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 36 3C 42 46 47 52 53 55
56 5F 6C
VIN: WAUVVAFR3AA056056 Mileage: 187260km-116357miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CAUB) Labels:. 079-907-560-CAU.clb
Part No SW: 8T0 907 560 T HW: 8T0 907 560
Component: 4.2l V8/4V H25 0005
Revision: 76H25---
Coding: 01140009190F0120
Shop #: WSC 02329 006 1048576
VCID: 4BC370ABE3C6F0B2FA9-801E
VINID: 9D19669915A20D14401460051859444D28
2 Faults Found:
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 - 004 - Malfunction / Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 187260 km
Time Indication: 0
Date: 2025.02.04
Time: 18:39:47
Freeze Frame:
RPM: 878 /min
Load: 21.6 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 35.0°C
Absolute Pres.: 940.0 mbar
Voltage: 12.192 V
000080 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
P0050 - 004 - Malfunction / Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 187260 km
Time Indication: 0
Date: 2025.02.04
Time: 18:39:47
Freeze Frame:
RPM: 878 /min
Load: 21.6 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 35.0°C
Voltage: 12.192 V
Readiness: 0110 1101
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 H HW: 0B6 927 156
Component: 0B6 42 FSIUSA H05 0005
Revision: --H05--- CVN: 1C147449
Coding: 001012
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 3B23206BB3E640324A9-806E
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0030
Revision: -------- Serial number: --------------
Coding: 120D18
Shop #: WSC 22103 444 16923
VCID: 7AADE56FFCDCB93A11F-802E
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
Component: BCM2 1.1 H02 0327
Revision: 00002001
Coding: 0D0000
VCID: 78A9FF67C2D0AB2A67B-802C
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0210000001598007
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 C HW: 8T0 959 760 C
Component: MEM-BFS H10 0074
Revision: AA000000 Serial number: 00001001385277
Coding: 00017025002C00000000
VCID: 43D3588BCB9638F2029-8016
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01290120100192
Coding: 48122000
VCID: 005997879A00E3EA5FB-8054
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000449717
Coding: 26001091063CAF010000080300003D3D0F1C53880001016100 0000
VCID: 3C212377B668470A433-8068
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 220110 H14 0070
Serial number: SWF10010225843
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10760686
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN
Component: E1 - LDS H08 0090
Serial number: 00000000001201101402
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51241003204715
Coding: 200102
VCID: 47CB4C9BFFAE14D2DE1-8012
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H39 0560
Serial number: 003EGD05GV3F Dataset Number: 8T0909602K 0001
Coding: 303338334330303030304A55304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 42DD5D8FD40C31FA09F-8016
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 HW: 8K0 959 339
Component: BF-Gewichtss. H01 0050
Serial number: 5810000R0900005BVK
Crash sensor for side airbag: driver side:
Serial number: 6334MSME4F2501325
Front Passenger's Side Airbag Crash Sensor:
Serial number: 6344MSME5003773ED
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 6352QSME624D0D1EU
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME674B380EV
Crash sensor for front airbag: driver side:
Serial number: 63732SME254F4E224
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME744D0F369
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319JAQ000KS
Coding: 000036
VCID: 3D272E73AD724E0274D-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 N HW: 8T0 920 981 N
Component: KOMBIINSTR. H36 0255
Revision: 00000000 Serial number: CSJ762X1A
Coding: 8B1701000300D705020000
Shop #: WSC 60873 003 1048576
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0105
Revision: FB900055 Serial number: 5500F101150260
Coding: 00C303
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 10003198150110
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00001001384614
Coding: 00197B25002C00000000
Address 3C: Lane Change Labels: 8K0-907-566.clb
Part No SW: 8K0 907 566 H HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0030
Revision: 00H01000 Serial number: 6PZ 009 014-82
Coding: 0000004
VCID: 3C212377BA68470A433-8068
Subsystem 1 - Part No: 8K0 907 568 H
Component: J0770_SWA_Slave_H01 0030
Subsystem 2 - Serial number: 6PZ 009 014-92
Subsystem 3 - Serial number: 5F26.01.1000H010003C320953ÿ
Subsystem 4 - Serial number: 320953ÿ
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 J HW: 8T0 959 793 D
Component: TSG FA H07 1201
Coding: 011C13224E00120102
VCID: 50F967C70AE0D36A8FB-8004
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0126399123
Coding: 0106029A007A440500B0003200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000211804
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H01 0220
Serial number: 0123456789ABCDEFGHIJ
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34882001144501
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 J HW: 8T0 959 792 D
Component: TSG BF H07 1201
VCID: 4FFB64BB17DECC92961-801A
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000555423
Shop #: WSC 00000 000 00000
VCID: 34310B579E388F4A8B3-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000002
Shop #: WSC 06324 000 00000
VCID: 77ABFC5BC3CEA4526E1-8022
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335A/0A7549657
Coding: 020000010000000001
VCID: 1D67CEF30DB22E0254D-8048
1 Fault Found:
00003 - Control Module
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Mileage: 178850 km
Time Indication: 0
Date: 2009.11.17
Time: 18:45:21
Freeze Frame:
Bin. Bits: 00000000 00001000
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 664 F HW: 8T1 035 664 B
Component: H-BN-NA H47 0189
Revision: -------- Serial number: 490BV0A7545451
Coding: 010200020206A1EF51000B0E000000030000
VCID: 3B23206BB36640324A9-806E
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356AO0A1182903
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000456799
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H03--- Serial number: 525PA8-J9Z90M4
Coding: 1000008
VCID: 38293F678E506B2AA7B-806C
End----------(Elapsed Time: 01:43, VBatt start/end: 12.3V/12.3V)-----------
