Results 1 to 8 of 8
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    New APR B9 S4/S5 Intake System: Big power. Full system. Low price.
    Introducing the APR Full Intake System for the Audi S4 and S5 (B9) 3.0T EA839
    Product Page
    APR is proud to unveil the Full Intake System for the Audi S4 and S5 (B9) 3.0T EA839—an all-in-one solution designed to deliver maximum airflow, enhanced turbocharger efficiency, and real, measurable performance gains.
    The APR Full Intake System is perfect for Audi enthusiasts seeking the ultimate intake upgrade. Unlike others that address only a portion of the intake system, requiring the inlets and outlets to neck down to the factory diameter for compatibility, this comprehensive solution replaces every component from the inlet scoop to the turbocharger inlet. This eliminates restrictions throughout the system, ensuring unmatched airflow and turbo performance with the largest inlet physically possible.
    Key to the system’s superior performance is its optimized design. Making the inlet as large as possible is the goal but space is extremely limited. By maximizing the internal diameter with thin-walled heat-resistant composite materials, APR achieves an impressive 31% more airflow compared to stock. This translates directly into improved turbocharger efficiency, faster spool times, and significant power gains, adding +19 AWHP and +20 AWFT-LBS of torque when paired with the APR Stage 1 (93) tune.
    Additionally, the APR Full Intake System is engineered with functionality, performance, and sound in mind. The PEX airbox shields the filter from the engine bay, while its thoughtfully placed cutouts provide additional airflow and a refined engine sound. A massive 7” x 7” washable pleated cotton gauze filter further enhances performance with vast filtration surface area while ensuring long-lasting usability.
    Whether you’re focused on unlocking power, enhancing turbo performance, or future-proofing your vehicle for upgrades, the APR Full Intake System is the only intake you’ll ever need.
    Testing Results That Speak for Themselves
    The performance of the factory intake system is no match for the APR Full Intake System. The stock setup is limited to a maximum flow of 400 CFM at 28” H2O, whereas our full intake system achieves a significant 31% improvement, flowing 525 CFM under the same conditions.
    This increase in airflow is paired with a dramatic reduction in pressure drop across the system, allowing the turbocharger to spool faster and operate in a more efficient range of its compressor map. The result is not just theoretical—it’s power you can feel.
    On our Stage 1 (93) tuned Audi S4, simply installing the APR Full Intake System delivered an additional +19 AWHP and +20 AWFT-LBS of torque, proving its capability to unlock your vehicle’s full potential.
    Product Page
    Features:
    • Complete System Replacement: Includes inlet scoop, airbox, filter, and turbo inlet pipe, eliminating all factory restrictions.
    • +19 AWHP & +20 AWFT-LBS Power Gains: When paired with APR Stage 1 (93).
    • 31% More Airflow: Improved from 400 CFM (stock) to 525 CFM.
    • Enhanced Turbocharger Efficiency: Reduces pressure drop, allowing the turbo to spool faster and operate more efficiently.
    • High-Temperature Composite Turbo Inlet: Enables thin-wall tubing for maximum internal diameter and airflow.
    • PEX Airbox: Heat-shield design with additional flow paths in low temperature zones.
    • Massive Washable Filter: 7” x 7” pleated cotton gauze with a 5.5” frontal inlet and 4” outlet for superior filtration and performance.
    • Future-Proof Design: Billet turbo inlet adapter accommodates larger turbos with a simple swap.
    • All-Inclusive Kit: Includes OEM gaskets, clamps, and hardware for an easy, bolt-on installation.
    • Emissions-Friendly: Requires no tuning and is compliant with emissions standards.
    • Improved Engine Sound: Adds a sporty, refined tone without being overbearing.
    Product Page
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Jan 04 2009
    ne
    Arin,
    Can you go into how this version is different than the previous intake and how is it been tested to assure it doesn't have the same issues as the previous iteration?
    Aug 23 2008
    Auburn, AL
    The previous system had a PEX turbo inlet. We've changed it to a higher temp composite material. This system has been on our development cars for around a year or so.
    Junior Member Two Rings
    May 14 2021
    Northeast
    Future B9 SQ5 fitment?
    Aug 23 2008
    Auburn, AL
    Yes, we havre a different system in the works.
    Apr 03 2016
    1972 Buick GS Stage1, 1971 Trans Am, 1970 Buick Sklark Custom Convt, 1968 Pontiac Firebird(x2)
    San Antonio
    I've been waiting for this, mine was delivered today.
    Jan 28 2022
    Seattle area
    Quote Originally Posted by Arin@APR View Post
    Will there be available an optional integral turbo inlet/intake pipe that is sized for and will directly bolt up to the APR stage 3 turbo?
    2021 Audi SQ5 Prestige SSP w/Sport Exhaust and APR Stage 3 (91 octane) - 0-60 in 3.5 s and 1/4 mile in 11.6 s @ 117 mph
    Aug 23 2008
    Auburn, AL
    Yes, its fits! The pipe comes with the proper adapter for the factory turbo, and the turbo comes with a larger that bolts right up.
