Results 1 to 7 of 7
    Junior Member One Ring
    Jun 08 2009
    2011 Audi Q7 Prestige and 2002 Audi TT 225
    California
    B6 Audi A4 01V transmission problems
    I had the Tiptronic transmission go out on the B6 Audi. It is the 01V tip. I bought a replacement that had 98,000 miles on it. I changed all of the seals accessible without pulling the trans apart and installed it. The transmission still had oil in the pan as well as the Torque Convertor. I followed the procedures of filling the transmission until the oil started dripping out. I installed the fill pIug then started the engine. While watching the temperature, I shifted through the gears. The trans shifted hard through the gears. With the engine still running I removed the fill plug so I could continue filling the transmission. I could hear a sucking sound so I knew there was not enough oil. I added the oil as quickly as I could. I filled until the oil started dripping out again. I could not hear the sucking sound after I started filling the transmission. I took the car off the jack stands, started it and shifted into drive. The transmission would not shift. I used VAGCOM to check for error messages and there were none. I thought that the transmission pump may have lost it's prime. I disconnected the hardlines that go to the transmission oil cooler one at a time and filled them with oil. I started then engine and shifted the transmission into gear and it would not engage. I am at a lost and am trying to figure out the issue I'm having. I don't know if the pump is defective due to the initial lack of oil or some other problem. If anyone has any ideas of what may causing the transmission not to shift and can answer that in my thread, it would be greatly appreciated.*
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    When you said “ I took the car off the jack stands, started it and shifted into drive. The transmission would not shift.” this statement contradicts itself. Does the shifter move? Are you saying it shifts into a gear but the car won’t move? When you say you changed seals, which seals? Did you open up the trans or valve body at all or did you just drop the pan and change the filter?
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    Just for my own curiosity, because I don't think I've ever done transmission work on an automatic. This couldn't be a TCM or IMMO issue could it?
    Nov 13 2009
    Quote Originally Posted by TobiqueSlang View Post
    If it was the TCM that was pooched, then you wouldn’t be able to log into the module with VCDS. Since he can log into the TCU and check codes, which it didn’t have any, then the TCM is fine. Immo only stops the car from starting and staying running and has nothing to do with the trans.
    There is most likely a linkage issue depending of how deep he went in to changing seals. If he took the valve body off, there is a little slider inside the body that moves a piston. If he didn’t line that up properly, he would shift the shifter and not be selecting any gears. If he didn’t open up the trans, then it’s most likely he didn’t pop the selector cable back on properly and it popped off while shifting through the gears. But he did get sound and a change in rhythm when he shifted the first time with low fluid so it’s a big question mark to me why the car won’t move when he puts it in gear.
    Jun 30 2008
    Erie, Pennsylvania
    I don't like your fill method. You should have done the following:
    - fill the pan until it drips
    - start the engine
    - fill again until it drips
    - run through each gear lever position (2-3 seconds in each position) with foot on the brake pedal and back to park.
    - throw the plug in, you're done.
    - finally, shut off engine
    - If the pan is warm, but you can still hold your bare hand on it, you're good.
    - If you do as above, you should be on the cold side of the spec temp and thus be very slightly overfilled (we're talking an ounce or 2), which is perfect.
    Based on your description, I can almost guarantee you didn't fill it enough. You waited until the spec fill temperature, and then added a bunch of missing fluid. So now (with the time delay of adding that fluid) you're likely well past the spec temp and it will be underfilled by some amount. Also, you asked it to select a bunch of gears and such while it was nearly out of fluid, so that's not great and those valve body circuits will be empty. I didn't see that you went back and fixed that (ie: you didn't run through the gear positions with enough actual fluid in the sump).
    I think you need to fill it again (cold) and see what happens. To top off in this case (without draining any of your new fluid), I would do the following:
    - Cold Start the engine
    - Remove the fill plug
    - Fill till it drips
    - Run through each gear position and back to park
    - Install fill plug
    - Shut off engine
    - See if you car works now.
    Jun 08 2009
    California
    I changed the torque converter seals, output shaft seal etc… I did not open the transmission up. The shifter moves in all gear ranges but the transmission itself will not engage into gear after selection whether it be reverse, drive, tip. It wont engage on any gear selected.
    Nov 13 2009
    When you installed your trans, did you put the converter on the engine and bolt it down to the flex plate then install the trans or did you install the torque converter on the trans before install? It is highly important to install the torque converter properly with the notches in the correct orientation. The converter will engage on the shaft like you are hitting a wall then clunk down again when you wiggle it into the notches. Do you recall how you installed it?
