Results 1 to 4 of 4
    Jul 22 2016
    2011 A4 2.0 CVT FWD
    Atlanta
    Help....?!? Multiple issues with a 2013 Q5 - intake runner and epb problems
    Hey folks-
    I'm pretty baffled here. 2013 Audi Q5. I just pulled and rebuilt the motor for a guy because of the usual ring issues. The rebuild went fine. But I am having multiple issues, and the car barely tries to start.
    I got several codes: p0343, for camshaft position sensor. I replaced the sensor, and at least that code went away and has stayed away. But I keep getting P2016 (and P2014 occasionally too), - "intake manifold runner position sensor/ switch circuit bank 1a". FWIW, the car barely cranks and usually doesn't start. However, when it does, the car runs and drives just fine (except for the frequent parking brake warnings).
    I've followed all the specific instructions from Ross-tech about intake runners on the 2./0 TFSI - prerequisites and all, but VCDS keeps giving me green error messages that it won't or can't run the test/adaptation for safety(?) reasons or something similar. I'm really getting frustrated at this point! FWIW, I stole an intake runner position sensor from a good donor motor and installed it - it made no difference.
    Also - when this car showed up here, the EPB wasn't working. The last garage that saw the car tried to fix the problem, but gave up, and just decided to unplug the EPBs let the owner fend for themselves on getting it fixed elsewhere. I don't know what they tried. I mention this because I've been trying to use VCDS to get into that EPB controller and try to put the car into "start lining change mode". Again, having followed all the VCDS instructions, I only get the red message: "ERROR: conditions not correct or request sequence error".
    (I was about to go pull the rear brakes and manually retract the EPBs in the hope that it might do some good at least as far as the EPB goes. (And i know not to even try to fool with VCDS with the rear brakes out, etc. But I don't know if that might only make the EPB situation worse...)
    Can anyone help steer me in the right direction?
    I'm attaching the full VCDS scan below. Sorry its so darn long but that's what the instructions say to attach.
    Saturday,01,February,2025,19:26:08:57047
    Chassis Type: FP-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
    6D 72
    VIN: WA1LFAFP4DA095503 Mileage: 282640km-175624miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (DET-CPMA) Labels:. 06H-907-115-CDN.clb
    Part No SW: 8R1 907 115 B HW: 8K2 907 115 L
    Component: 2.0l R4/4V TF H09 0006
    Revision: ECH09--- CVN: FC1303C8
    Coding: 6A2A0013242600062000
    Shop #: WSC 55130 002 1048576
    ASAM Dataset: EV_ECM20TFS0118R1907115B 001007
    ROD: EV_ECM20TFS0118R1907115B.rod
    VCID: 34310DF4AEB682DA8B3-8060
    VINID: 9D105C5915A01144402451400CEB18A5B1
    4 Faults Found:
    17403 - Implausible Data Received from Parking Brake Control Module
    U0417 00 [00100111] - -
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 18:01:09
    Engine RPM: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 78 ∞C
    Intake air temperature: 38 ∞C
    Ambient air pressure: 970 mbar
    Voltage terminal 30: 11.779 V
    Unlearning counter according OBD: 40
    CAN status - engine control module-Bits 0-7: 0
    CAN status - transmission control module-Bits 0-7: 0
    CAN status - brake control module 1-Bits 0-7: 0
    CAN status - brake control module 2-Bits 0-7: 0
    selected gear-Bits 0-7: 0
    2979 - Intake Manifold Flap Position Sensor (Bank 1)
    P2014 00 [00100111] - Electrical Malfunction
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 282647 km
    Date: 2000.00.00
    Time: 00:00:00
    Engine RPM: 86.00 /min
    Normed load value: 51.8 %
    Coolant temperature: 72 ∞C
    Intake air temperature: 39 ∞C
    Voltage terminal 30: 5.913 V
    Mean injection time: 0.000 ms
    Engine operating condition: Idle
    Engine operating condition-Test_Program_Channel 87: 5
    2980 - Intake Manifold Flap Position Sensor (Bank 1)
    P2016 00 [00100100] - Short to Ground
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 18:01:09
    11510 - EVAP System Temp Sensor
    P2025 00 [01100100] - Implausible Signal
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 282647 km
    Date: 2000.00.00
    Time: 00:00:00
    Intake air temperature: 40 ∞C
    Voltage terminal 30: 11.449 V
    Readiness: 1110 0101
    Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
    Part No SW: 8R1 927 158 C HW: 0BK 927 156 AL
    Component: 0BK 20TFSIUSA H16 1002
    Revision: --H16--- CVN: AE5A42EC
    Coding: 000002
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_TCMAL551211 002020
    ROD: EV_TCMAL551211_002_AU48.rod
    VCID: 3E252FDC90FA588A6D7-806A
    No fault code found.
    Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
    Part No SW: 8R0 907 379 AL HW: 8R0 907 379 AL
    Component: ESP8 quattro H09 0040
    Revision: -------- Serial number: --------------
    Coding: 151D1803
    Shop #: WSC 06335 000 00000
    VCID: 0A4DB30C9C32A42A01F-805E
    1 Fault Found:
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 59
    Mileage: 282647 km
    Time Indication: 0
    Date: 2025.02.01
    Time: 17:57:50
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0782
    Hex Value: 0x001A
    Hex Value: 0x097B
    Hex Value: 0x0000
    Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
    Part No SW: 8K0 953 568 L HW: 8K0 953 568 L
    Component: Lenks.Modul H03 0005
    Revision: -------- Serial number: 90372MDH001GQ
    Coding: 000017
    VCID: 43D35E28FB983562029-8016
    Component: E221 - MFL H03 0004
    Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
    Part No SW: 8R0 920 980 T HW: 8R0 920 980 T
    Component: KOMBIINSTR. H35 0556
    Revision: 00200000 Serial number: UWH10YC4E
    Coding: 8BB622000301D705020000
    VCID: 4ACD730CDCB2E42AC1F-801E
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
    Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
    Component: GW-BEM 4CAN-M H11 0056
    Revision: 1Y070028 Serial number: 2841Y1341701B7
    Coding: 80C303FF00
    Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
    Component: J367-BDM H07 0141
    Serial number: 30103505001461216636
    1 Fault Found:
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 12
    Reset counter: 99
    Mileage: 282647 km
    Time Indication: 0
    Date: 2025.02.01
    Time: 17:57:02
    Freeze Frame:
    Bin. Bits: 10111
    Voltage: 11.70 V
    Count: 6
    Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
    Part No SW: 8R0 909 144 F HW: 8R0 909 144 B
    Component: RCEPS H37 0507
    Revision: 00001000 Serial number: 0020415156 Dataset Number: 8R0909852H 0021
    Coding: 100000000000
    Shop #: WSC 06334 000 00000
    ASAM Dataset: EV_RCEPSAU48X 008014
    ROD: EV_RCEPSAU48X_008.rod
    VCID: 3B2326C883E84DA24A9-806E
    2 Faults Found:
    16387 - Function Restricted due to Insufficient Voltage
    U1400 00 [00001000] - -
    [Keine Freigabe der Lenkunterst¸tzung aufgrund Unterspannung der Versorgungsspannung]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 17:59:54
    Write only channel
    18689 - Terminal 30
    U140A 00 [00001000] - Open Circuit
    [Ausfall der Versorgungsspannung (Kl30 oder Kl31) im Stillstand (unkritisch)]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 99
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 17:59:42
    Write only channel
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
    Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
    Component: TSG BF H02 0508
    Revision: Serial number: 0000058460613
    Coding: 011D13205E00440004
    VCID: 4EC57F1C20DAC80A9D7-801A
    Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
    Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
    Component: EPB-4 H01 0003
    Revision: -------- Serial number: 00000001295829
    ASAM Dataset: EV_ParkiBrake 001027
    ROD: EV_ParkiBrake_AU48.rod
    VCID: 382939C4B2DE66BAA7B-806C
    2 Faults Found:
    131328 - Switch for Electric Parking Brake
    C100C 01 [10001001] - Electrical Failure
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 17:55:54
    Voltage terminal 30: 11.9 V
    Internal Fault ID: 10
    Network management state: normal
    Function light in parking brake button: On
    Red operating lamp: On
    Red warning lamp: On
    Green operating lamp: OFF
    Yellow warning lamp: On
    Terminal 15 status: On
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    ACC requested apply: not active
    Auto Adjust: not active
    General Inspection Function: not active
    Internal Parking Brake state: static
    Status of parking brake button: Malfunction
    Status ParkingBrake left: applied
    Status ParkingBrake right: applied
    70912 - Left Parking Brake Motor Voltage Supply
    C100D 13 [10001001] - Electrical Malfunction
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 26
    Reset counter: 59
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 17:55:54
    Internal Fault ID: 26
    Red warning lamp: OFF
    Yellow warning lamp: OFF
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    6D 72
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 18:01:09
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 282647 km
    Date: 2000.00.00
    Time: 00:00:00
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 18:01:09
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 282647 km
    Date: 2000.00.00
    Time: 00:00:00
    Coding: 151D1803
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 59
    Mileage: 282647 km
    Time Indication: 0
    Date: 2025.02.01
    Time: 17:57:50
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0782
    Hex Value: 0x001A
    Hex Value: 0x097B
    Hex Value: 0x0000
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
    Component: BCM2 2.0 H12 0633
    Revision: 00002001
    Coding: 0D854000000000000000
    VCID: 04519D34BE16F25A7B3-8050
    Subsystem 1 - Part No SW: 8K0 959 754 B HW: 8K0 959 754 B
    Component: FBSAUDIB8 IDG H71 0083
    Serial number: 0513000029863016
    Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
    Component: J764 ELV MLB H40 0046
    Serial number: 2313000068418004
    2 Faults Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 282647 km
    Time Indication: 0
    Date: 2025.02.01
    Time: 18:11:04
    02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 99
    Mileage: 282647 km
    Time Indication: 0
    Date: 2025.02.01
    Time: 19:22:39
    Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
    Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
    Component: AirbagVW-AU10 H45 0610
    Serial number: 003GPD91JCEQ Dataset Number: 8R0909602B 0021
    Coding: 303634313432303030304A55304C38523053
    ASAM Dataset: EV_AirbaAU10SMEAU416 002004
    ROD: EV_AirbaAU10SMEAU416.rod
    VCID: 47CB4A38CF201942DE1-8012
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
    Component: BF-Gewichtss. H02 0040
    Serial number: 5810000R130000D663
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME7903685AL
    Front Passenger's Side Airbag Crash Sensor:
    Serial number: 6344MSME79441533A
    Rear Side Airbag Crash Sensor (on driver's side):
    Serial number: 6352QSME2F2F1C48-
    Passenger side rear thorax airbag crash sensor:
    Serial number: 6362QSME652F276CX
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME2C2F254CA
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME2C2F07522
    2 Faults Found:
    13635840 - Supply voltage
    U1011 00 [00001000] - Voltage too Low
    [Powersupply lower threshold fall short of]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 19:20:43
    9483264 - Seat Occupied Recognition
    B10B4 00 [00001000] - Function Restriction due to Undervoltage
    [Bladder Mat: functional restriction because of low voltage]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 99
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 17:59:59
    Coding: 80C303FF00
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 13
    Reset counter: 99
    Mileage: 282647 km
    Time Indication: 0
    Date: 2025.02.01
    Time: 17:57:02
    Freeze Frame:
    Bin. Bits: 10111
    Voltage: 11.70 V
    Count: 6
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 17:59:54
    Write only channel
    18689 - Terminal 30
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 99
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 17:59:42
    Write only channel
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 17:55:54
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 27
    Reset counter: 59
    Mileage: 282647 km
    Date: 2025.02.01
    Time: 17:55:54
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Did you check the battery?
    Jul 22 2016
    2011 A4 2.0 CVT FWD
    Atlanta
    Good point! - I was beginning to wonder about the battery and/or starter motor. I had the battery charging up overnight and it started OK (if not immediately) the one time I tried it today so far. Let me go check....
    - So -resting voltage is at 13.2 v seems pretty good, and when cranking, it drops to 11.5v, which I hear is also OK. Now the car starts OK, but it consistently cranks over for a pretty long time before actually firing up. And each time I get those codes again - P2014, P2016, and this time the P0343 is back again too (camshaft position sensor A circuit high bank one or single sensor).
    Jul 22 2016
    2011 A4 2.0 CVT FWD
    Atlanta
    We still haven't figured this out.
    The car now has a brand new battery, and the cat was suspect, so that got swapped out too, with new sensors. And the car still barely starts, and is still misfiring badly. FWIW, the starter will spin the motor over for maybe 10 seconds, and then it will fire up. And it doesn't seem like the motor is trying to start for those first 10 seconds - there's no hints of any cylinders firing at all. But then it just starts. My uninformed guess is that this is an ECM issue, maybe like a "limp mode" of sorts.
    The most recent codes:
    P0341 -camshaft sensor (we've seen this intermittently)
    P0016 -camshaft correlation (this is the first we saw on that
    "idle control system" code (P0560? I'm not sure on that code number) - the first time we've seen this code
    and lots of random misfires (P0300 through P0304)
    I already replaced the camshaft position sensor once, and I guess I will pull the top timing cover and make sure the cams are where they should be at TDC, in case I somehow messed up when installing a new timing kit. (I've done lots of timing belts and timing chains over time, and haven't messed one up yet. But I'll go double check.
    This is the first time we've gotten that P0016 "camshaft correlation" code too. My guess would be that its a transient code, probably related to the P0341 code that we're frequently getting.
    Any guesses where else we might look?
