Results 1 to 6 of 6
    Junior Member Two Rings Roxanne32's Avatar
    Jul 17 2023
    15 Challanger skat pack
    Kennewick, Washington
    Valve Stem Seals
    hi yall couldn't find what i was looking for so i made a thread, i just got ahold of a 99 a4 wagon and it burns oil at startup i have the tools i need to do the job but have a few ?s
    oh this is a non vvt aeb head
    1. should i convert to vvt or not
    2. what valve stem seal/s should i get as their are to many got dam different makers , im going to be doing this with the head on
    what seals do yall recommend i plan on pushing the wagon to 300hp or close to it if i have to change head/engine in order to get vvt so be it
    any and all advice or info is greatly appreciated
    Veteran Member Four Rings BlazinB5's Avatar
    Nov 12 2010
    Stillwater, MN
    9 times out of 10 it's a blown turbo that causes a puff of white smoke on startup, and white smoke when you're accelerating. I've had five cars with a 1.8T, and not a single one had issues with valve stem seals/smoke.
    2001 Allroad 2.7T
    2000 A6 4.2 (parted out)
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Nov 13 2009
    Victoria, B.C., Canada
    Valve stem seals that go are usually a puff of smoke on deceleration. When I repaired a head on a smoking B5, the seal was floating up and down the valve. It was no longer seated on the guide. Replaced them and no more smoke out the tailpipe. If you are getting smoke when getting on the throttle then it’s most likely not the stem seals.
    Jul 17 2023
    no smoke after a min of running and no smoke when reving just at startup and no smoke while driving no blue or white smoke but the smell is deffo oil
    Nov 13 2009
    Smell where? From engine bay or tail pipe? If engine bay then it’s most likely valve cover and cam tensioner gaskets from dripping oil on the manifold and/or exhaust. If you don’t have a good or missing seal between the fire wall and rain tray, smell will get into the cabin via the cabin air intake under the rain tray.
    Jul 17 2023
    its deffo coming from tailpipe
