Quote Originally Posted by Cybersombosis View Post
So the sequence for the signal is speed sensor to the cluster then from the cluster to the ECU so you would log in to the cluster and advanced measuring blocks and type “speed” and it should show up. Just tick that off and it will show up in the window and go for a spin. If you are getting a speed in VCDS but nothing on the cluster then it’s most likely the cluster. If you have a spare cluster, try popping that in to confirm. If you aren’t getting a reading then it’s something before the cluster. Tone ring, speed sensor or wiring.
Thank you so much! That is very helpful!
