Results 1 to 9 of 9
    Established Member Two Rings SS1LE02's Avatar
    Aug 01 2009
    2009 CTS-V, 2006 Silverado 4x4, 1967 Chevelle SS convertible
    Minneapolis
    Front 17z brake upgrade
    So I’m doing this upgrade and wondering if I need to shave/grind any thing off each caliper. My wheels are VMR 701s 18x8.5, +35mm
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    mount them and see if they fit, then grind if needed.
    odds of someone on here, actively posting, with the exact car and exact wheel setup who did a 17z kit are basically zero.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Veteran Member Four Rings belms4's Avatar
    Apr 17 2019
    2000 silver S4, 2001 imola S4, 2002 Avant nogaro RS4 conversion
    I have vmr v810s in same specs. They clear 17zs easily. But yeah test fit your wheel over when you mount one and find out. Small wheel spacers would be your other option if they don't clear.
    Sent from my SM-F741U1 using Audizine Forum mobile app
    Veteran Member Three Rings wpfahl's Avatar
    Jan 07 2013
    2001.5 S4 Avant. 1997 A6 Base, 1997 A6 Avant, 2014 Jetta Hybrid, Ford F250
    California
    I have VMR [emoji[emoji6]]x[emoji[emoji6]].[emoji6] et[emoji6] and they clear [emoji[emoji6]]z’s no spacers. You may need to grind some material off the bottom of the knuckles/uprights to clear the rotors.
    [emoji6]/[emoji6]-[emoji[emoji6]] tires with some minimal material removal to the aluminum uprights to clear the tires.
    Jan 07 2013
    California
    That’s ugly
    Sent from my magic phone
    Jan 07 2013
    California
    They clear those calipers
    Nov 02 2013
    Aside from wheel clearance, I had to have a small amount of material removed from the inside of the mounting bolt bosses on the 17Z calipers to center the caliper over V70R rotors About 2MM IIRC. You gotta measure.
    LDRXN
    Junior Member Two Rings
    Mar 01 2024
    Boulder Colorado
    I know this post is old and your have probably figured this out by now but if it helps get a spacer.
    I'm not on the same wheels, I am on knp 18/8.5 +35 and if anything those have a little more dish than the 710's and I have front and back 17z setup with a 12 mil spacer and the fitment is soo good. from tire to fender and I have about 1cm of clearance from caliper to spoke. I'm on 235/40 tire, a lil stretch.
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    ^Looks great!
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
