Hybrid View
    Sep 17 2023
    Scoring in cylinders. How did that happen?
    Q7 3.0 tfsi 2015 4L.
    Year and a half ago cylinders were fine.
    Terrible oil consumption of 1 quart per 1000 miles quickly risen its appetites to 1qt per 500.
    Several month ago started to smell gasoline in oil. Garage did this endoscope check saying they found corrosion and scoring. They are proposing ironcast sleeving. Compression in 5th cylinder is barely 8, the others 12.
    For now they say fuel pump should be replaced which allegedly caused oil dilution.
    Any thoughts?
    P.S. Attached images links, but they don't show. Weird tooling.
    https://ibb.co/rQvV2Yh
    https://ibb.co/SQWjzrk
    May 20 2010
    Quote Originally Posted by Nickolodeon View Post
    Any thoughts?
    Consumption suggests piston rings. Scoring might have been a buildup of carbon stuck to the edge of the piston or chunked of the valves. I'm not sure how the fuel pump caused fuel dilution because it feeds the injectors unless it's way over pressure; injectors not working right sound more likely to me (like stuck open). If it ever had a lot of effort to start, could have washed the walls with fuel too.
    On your images, you have to show the actual URL ending in .jpg (or similar).
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Mar 21 2019
    Florida
    We get a lot of q7s traded in at the dealer i work for and nearly every one of them has this issue. Carbon buildup in the rings causes poor lubrication and cylinder scoring.
    Veteran Member Four Rings namvar's Avatar
    Jul 10 2014
    2024 SQ8 Prestige, 2018 A4
    SF Bay Area
    I had a 2013 with extended warranty. They finally replace the motor for me at 85K miles. Ran great until 210K miles but the oil consumptions was back to the pre-engine swap days. I had the engine carbon cleaned every 50K miles.
    2015 RS5: Mythos Black, Tech Package , Dynamic steering, Black Optics, Folding side mirror upgrade, internal LED lights, Eventuri Intake, Akrapovič exhaust, KW DDC ECU, lots of CF
    2013 3.0T Prestige Q7: Sport pedals, LED interior lights
    Active Member One Ring AANgry90q's Avatar
    Jan 11 2024
    rochester ny
    High pressure fuel pumps can leak fuel into the crank case as they are driven off of the camshaft, diluting oil which can cause scoring/low compression. Carbon however is one of the biggest more likely killers as was said, (right up there with tunes) 10k plus oil change interval’s and poor quality fuels cause buildup so excessive clogs rings, can break valves, bend rods….that “corrosion” looks like the plating/coating on the cylinder walls delaminating….wear…
