I'm struggling a bit with the beyond limit handling of my B8 S4 (non-sport diff) and wondering if others have similar issues or if I went overboard on the setup. (or maybe it's just a skill issue)
Today I smoked the bumper, grille and at least the rad and intercooler when I spun it into a dirt embankment
In the past I've had issues with sliding getting out of hand on wet autox days. (a couple of very close calls) The angle of no return seems to be EXTREMELY low, like 10 or 15 degrees. Angles at which my Miata will happily hold a slide.
I have a 2.0T b7 that I have been doing rallyx in, including a heavily iced out race. I've finished 1st in 3 events, 3rd in 1 event, and snapped a CV shaft while in a comfortable 1st place at another (who would have thought that dumping the clutch at full lock was a bad idea?). I run it in the highly competitive stock class and my times would usually also place in Prepared.
Not a flex, just trying to make it clear that I do have good understanding of how to control an AWD car well past the limits. I run the rallyx events with my ABS fuse pulled and am fully convinced that I could have avoided the embankment with my ABS fuse pulled.
The only mods I have done are a rear sway bar, Bilstein B6 all around, and I have the rear toe set to zero. Maybe this is too aggressive?
I don't think so because relative to both the B7 and Miata trail braking doesn't put the tail out as aggressively.
The issue I am having is that there doesn't seem to be a right way to control the throttle. In my B7 getting out of a slide is as simple as turning into it and getting into the throttle. In the Miata it's the typical RWD dance with the throttle. In the B8 it seems like throttle makes it spin more, and any amount of modulation or lifting transfers traction to the front and also makes it spin more.
Any B8 owners have a similar experience or am I just an idiot?
