I have a magnetic oil drain plug and on the last oil change it didn't want to come out because a piece of metal was stuck to it that couldn't come through the hole. There was also randomly longer startup times on cold starts. So I checked the HPFP cam follower now and the end is basically gone, only the tube was left so I replaced it. Both the oil filter and drain plug were clean with no debris, just like always.
Now I'm wondering if I need to still inspect the chain tensioner for damage or if it's relatively safe, considering that the piece did come down into the pan.
Vehicle has ~172k miles and at ~157k miles almost 2 years ago the cam follower was replaced with a Standard Motor Products one as preventative maintenance. Engine is stock and runs well. Oil gets changed every 3 to 3½ thousand miles.
I didn't know that the cam follower needs to be changed so frequently. In your experiences, how long does the INA or OEM one last? The cam lobe looks a bit scratched but feels smooth.
