Results 1 to 2 of 2
    Nov 06 2023
    New England
    Driver's side door sensor not working.
    My keylesss entry hasn't been working. I took part the door handle and looked at the connections for the sensor. Zero corrosion. Also I swapped out with the rear drivers side sensor. Front sensor works in the rear fine and the rear does not work up front so it seems the sensor itself is fine. My OBD doesn't seem to pull up any problems. Where do I go from here?
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Open up the door panel and check for frayed wires/insulation on the inside? There's a thread around with pictures of possible connectors and wires that need to be repaired.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
