Results 1 to 7 of 7
    Veteran Member Four Rings jamerican1's Avatar
    Nov 15 2009
    2008 A4 S-Line Titanium TQM, 2000 A4 1.8tqm, 1993 Audi 90S(sold)
    VA
    K04 Kit/Components
    I just put my B6 on the road and I'm thinking about upgrading to a K04. If anyone has a kit laying around that you'd like to get rid of, please let me know. ECUs, injectors, maybe even a front mount... Show me what you got!
    Unf*ckwithable
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by jamerican1 View Post
    Honestly, I'd go w/ a APR manifold and at a minimum and go to a full frame turbo. The K04 is not really anything impressive. The Eliminator turbos weren't too bad of an upgrade when available.
    Matt has one for sale that I'd pick up if I were you: https://www.audizine.com/forum/showt...1-Apr-manifold
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Nov 15 2009
    VA
    Quote Originally Posted by BumblebVR6 View Post
    It's a stock block so I was just gonna do a mild, budget build. An eliminator setup would require rods no?
    Unf*ckwithable
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    eliminator setup - no rods required
    Nov 15 2009
    VA
    Quote Originally Posted by 1.8Turbo4me! View Post
    Hmmmm, many things to consider
    Unf*ckwithable
    Mar 13 2009
    MK3 VR6
    Houston, TX
    I'm running a Stage 3+ kit essentially w/ an upgraded 28rs turbo on stock rods. Motor has 245k miles as well. All in the tuning. Only running 15psi to limit torque.
    B6 USP Avant
    AMB + GSX28RS
    Junior Member One Ring
    Aug 22 2023
    California
    I’m finishing up a built 1.8t. I have a genuine borg warner k04 kit of your interested. It comes with an 034 tuned ecu which passes California emissions. Comes with bigger injectors (tt225), an er sport fmic, 034 intake pipe, and an 034 high flow cat. The turbo is a real k04-15 with no shaft play, let me know if your interested.
