Results 1 to 7 of 7
Thread: zf8 tcu swap
    Established Member Two Rings dspl1236's Avatar
    Dec 15 2007
    '90 90q 2.6, '90 GTI 3.6, '12 A6 3.2T
    Akron, Ohio
    zf8 tcu swap
    I have a spare zf8 with tuned tcu. At some point if I swapped the tcu's or the whole transmission. Would this be just a protection adaptation? Just future planning.
    '13 A6 3.0T + '90 Jetta 2.0T 20v + '92 Corrado SLC + '90 90q 2.6 20v + '90 GTI Plum 3.6 VR6 + '89 200 10vt + '12 A6 3.2T + '01 A8
    Gone: '91 200TQA, '90 V8Qm, '97 A4 1.8T, 2x '98 A4 1.8T, '90 80Q, '90 CQ, '91 CQ, '91 CQ 1.8T, '91 200TQ, '95 90cs, '01 Jetta 1.8t, '08 Passat 2.0T, '13 GLI, '76 Audi Fox, '04 1.8T USP
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Theres an entire thread on this. Its not just a simple swap.
    18 S6
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    Quote Originally Posted by dspl1236 View Post
    Need more details. Why do you want to swap the tcu? Much easier to just tune your current transmission
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Dec 15 2007
    Akron, Ohio
    not sure what more there is to know? If my current zf8 died, and I plopped in a replacement unit. What more other than a protection issue might I face? If the tcu has a tune on it, what issues may arise? I bought a whole spare car, ecu was tuned, tcu still tuned.
    I understand there are no immo defeats (yet but in progress) but needing to adapt via odis. I may never swap it. Call it a technical exercise.
    Dec 15 2007
    Akron, Ohio
    I know the immo has been cracked on the Audi zf-8 transmissions. I am waiting for more details to trickle out.
    Jun 28 2019
    California
    go on nefmoto forum and search there is a guy who cracked it, but none publicly available that ive seen. Maybe you can reach out to him and slide him some coin
    IG:@stolens6
    Dec 15 2007
    Akron, Ohio
    I am aware. I have been on Nef for 10+ years... Was just passing along that the AL551 immo has been figured out. Just another tool available. That user "neuro" sells his own software. I am sure it will be more than the Odis rental time.
