Hi Guys, I have a new whirring noise in the car (B8.5 2015) and looking for some advice.
The noise starts at about 15mph and gets louder as you get faster. it's not related to engine speed and disappears at idle, doesn't change with the different gears.
Almost sounds like a distant air raid siren or like wind blowing through a cracked window.
I've run a scan and these were the faults. Whilst I know you shouldn't have any faults, I can't see anything that would be implicated?
I don't think it's the PCV as there isn't really anything at idle. Wondering if it is a wheel bearing, hoping not mechatronic
2015 B8.5 RS5, 67,000 miles. Video is the best I can do but you can't really make it out except the change in town at 30 seconds.
https://www.youtube.com/shorts/vxXxwO69X0o
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: OK 0000
30-Special Function II -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
1 Fault Found:
11926 - Valve for Exhaust Flap 1 (N321)
P3019 00 [00101111] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 105063 km
Date: 2024.08.22
Time: 17:48:19
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 67 C
Intake air temperature: 54 C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.028 V
Unlearning counter according OBD: 40
Engine status-Bits 0-7: 1
Engine oil temperature: 63.1 C
Engine operating condition: Idle
Engine operating condition-Test_Program_Channel 87: 5
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8T0 907 379 G HW: 8T0 907 379 G
Component: ESP8 quattro H09 0010
Revision: -------- Serial number: --------------
Coding: 2C5DCA
Shop #: WSC 06325 000 00000
VCID: 46D5538308A5C2AA257-8012
1 Fault Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 14
Mileage: 108275 km
Time Indication: 0
Date: 2024.12.04
Time: 19:12:05
Freeze Frame:
Hex Value: 0x9700
Hex Value: 0x4006
Hex Value: 0x1F23
Hex Value: 0x1DB7
Hex Value: 0x0000
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z14A1301D3
Coding: 80E3031600
VCID: 4CC161AB16C938FAF33-8018
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 3762724703
2 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 7
Fault Frequency: 9
Reset counter: 228
Mileage: 104862 km
Time Indication: 0
Date: 2024.08.15
Time: 18:01:01
03041 - Energy Management Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 42
Reset counter: 23
Mileage: 104862 km
Time Indication: 0
Date: 2024.08.15
Time: 21:01:02
Freeze Frame:
Bin. Bits: 00000
Voltage: 13.20 V
Count: 7
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109J90E7978155
Coding: 010103010000000001
VCID: 2D070C2F8D1311F2C4D-8078
1 Fault Found:
02984 - Connection between Impedance Converter 2 and Window Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 33
Reset counter: 23
Mileage: 104862 km
Time Indication: 0
Date: 2024.08.15
Time: 15:39:53
Freeze Frame:
Voltage: 13.20 V
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 670 M HW: 8R2 035 670 E
Component: H-BNT-EU H48 1036
Revision: -------- Serial number: 208J40E7518088
Coding: 150101020306A1EF45808F5E00000403040000000000000000
Shop #: WSC 56553 003 104857
VCID: 3E253B6350759A6A6D7-806A
Subsystem 1 - Part No: 8R0 060 884 HF
Component: EUR 2020/2021 3101
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130JU0E3170096
Subsystem 3 - Part No SW: 8T0 919 611 M HW: 8T0 919 611 H
Component: E0380 Bedient H02 0030
Serial number: 00000002030837
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
2 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 106030 km
Time Indication: 0
Date: 2024.08.25
Time: 13:04:23
Freeze Frame:
Text: DUA130,,D,0,0,6
03623 - Invalid Security/Release Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 175
Mileage: 104862 km
Time Indication: 0
Date: 2024.08.15
Time: 15:39:46
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H08--- Serial number: 525 PA8J37H16Q
Coding: 1022108
Shop #: WSC 00046 000 00000
VCID: 38292D7B7E51A45AA7B-806C
1 Fault Found:
03006 - Back-up Camera System not calibrated
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 175
Time Indication: 0
