Results 1 to 33 of 33
    Junior Member Two Rings
    Dec 07 2024
    Vancouver
    B6 A4 Misfire Cylinder 2
    Hey guys, first post on the forum, glad to be here.
    I bought a 2003 a4 1.8t a couple of months ago from a guy claiming to be a mechanic and have had a ton of issue with it, slowly getting them resolved but my current most pressing issue is I keep getting misfires on cylinder #2. When I first start the car cold it will misfire a couple of times sometimes. Driving in first and second gear is mostly good but when I'm in 3rd and above and pull power above 2500 rpm or am pulling power while going up a hill it misfires like crazy. Been trying to baby it around while I get this figured out but its not always easy where I live (good amount of hills in North Vancouver). This issue only started recently, before that the engine ran fine, I was able to drive up to the ski hill no problem. About 2 weeks ago I was heading up to the ski hill and it started misfiring like crazy in 3rd and above, I had to baby the car to make it as there are no turn arounds. It did have misfires 2 months ago but only slightly on startup, then my fuel pump died and I had no issues after it was replaced so I assumed my misfires were related to that and didnt have issues afterwards.
    Whats been done to the engine by my local shop since I've owned it:
    -valve cover seal
    -all new ignition coils
    -all new spark plugs
    -new fuel pump
    -2 injectors on cylinders 3 & 4 were swapped with spares that came with the car (amongst a box of other used goodies) they were not new but dont seem to be having an issue
    -oil filter housing gasket. there is still an oil leak here, the shop that I've had a majority of this work done by thinks the housing itself is cracked but I dont think that is related to issue
    The other night I plugged in VAGCOM and saw the following codes:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - - MIL ON
    16686 - Cylinder 2
    P0302 - 001 - Misfire Detected - MIL ON
    16839 - EVAP System
    P0455 - 001 - Large Leak Detected - MIL ON
    16826 - EVAP Emission Control Sys
    P0442 - 001 - Small Leak - MIL ON
    16727 - Camshaft Position Sensor (G40)
    P0343 - 001 - Signal too High - Intermittent
    I figured camshaft position sensor was a good culprit to my problem so I replaced it. I also removed all the injectors and tried to clean them out by actuating them with a power supply and spraying brake clean and sea foam through them. They all seemed to have the same spray volume and patterning. fired it back up and went for a drive while monitoring the misfires on vagcom, still misfiring heavily on cylinder 2. The camshaft position sensor code has gone away but they others remain. I'm not really sure where to go from here, could the EVAP Large Leak be a cause of this issue? and if so where do I look to find that leak?
    Any help would be greatly appreciated.
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Check wiring at the connectors
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Dec 20 2024
    Arizona
    If i were you. I'd try fixing that evap problem. Might not fix the cylinder 2 misfire. But my old 05 1.8 ran horribly until I fixed the evap.
    Sent from my SM-S908U using Audizine Forum mobile app
    Dec 07 2024
    Vancouver
    OK I checked the connector wiring, they arent the prettiest but they arent terrible either. Cylinder 3 injector 1 wire the insulation was cracked so I threw some electrical tape around it. Some of the other injector wire have electrical tape around them so peeled them to check the wires are still connected and they were so I retaped them. The entire injector wire harness loom is just electrical tape around all the wires, no protective plastic sheathing.
    Cylinder 2 coil wire the protective plastic sheathing has crumbled away a bit and there is a bit of green corrosion coming out of it, this could be my issue Im guessing?
    How much does a new wiring harness usually run?
    Any other possibilities?
    Also I will try to track down my EVAP leak, need to learn the system to do this though.
    Dec 07 2024
    Vancouver
    I just scanned the codes again and had the following 3. EVAP code is gone. Not concerned about the CAT at this point.
    3 Faults Found:
    16804 - Catalyst System; Bank 1
    P0420 - 002 - Efficiency Below Threshold - MIL ON
    P0300 - 001 - - Intermittent
    16686 - Cylinder 2
    P0302 - 001 - Misfire Detected - Intermittent
    Readiness: 0000 0000
    Dec 20 2024
    Arizona
    Have you ruled out. Spark plug ignition coil and injector? If the wire is corroded, that could be the cause. Did you check if the pins were corroded?
    Do you have fuel trim data?
    Dec 07 2024
    Vancouver
    Not completely I suppose. I assume that with the plugs and coils being new they would not be the issue but I can try swapping them with another cylinder 1 at a time to rule them out. Connector pins are not corroded.
    How do I pull fuel trim data? not sure what parameters they are. I went through the monitoring parameters list when I was taking my misfire readings and dont recall a fuel trim parameter but would have to check again.
    Also I think I found my evap leak issue. Check valve above the air box is blown out. Ill try to get another 1 and some hose clamps to replace it
    Dec 20 2024
    Arizona
    I've had new parts turn up bad. Move the injector sparkplug and coil to different cylinders. In case they are the issue, you can differentiate which one was the cause.
    Dec 07 2024
    Vancouver
    Ok I will try this when I have time again and see what I come up with.
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    One thing that hasn't been mentioned...the Coscast head used on the AMB engine tends to be notorious for cracking, especially around #2 cylinder.
    Just to rule it out, I'd pull the plug and inspect the plug as well as look in the cylinder through the spark plug well.
    Sent from my SM-S918U using Tapatalk
    Sep 10 2021
    Pennsylvania
    AvantNoir makes injector and ignition harnesses. His harness require a little work to install, but they're done the right way. I had a failed ignition harness, replaced it with a similar harness (didn't know about his at the time), and the problem went away.
    Like others here, I also had a cracked cylinder head (that was early in my ownership of the car like 5 years ago). Look inside the spark plug holes for coolant on top of your piston. That's a good indicator. Also, if your spark plugs are hard to remove, that's another indicator (my guess is that the hole go out-of-round).
    Start with the easy stuff first, though, before you go worrying about the head. Swap the coils and injectors like Imtryingtofixit suggested (lol I like that user name). Then get that trash wiring off of there and replace it. AvantNoir's harnesses go straight back to the ECU, are labeled, and you won't be connecting new wires to dead ones.
    Jun 30 2008
    Erie, Pennsylvania
    Looking down the plug holes with a flashlight, and compare the tops of the pistons (and the spark plugs that come out of each hole). If coolant is leaking into the cylinder, it will "steam clean" the top of the piston real nice-like. If that piston is way shinier and cleaner than the other 3, you know you've got water entering the chamber.
    Sep 10 2021
    Pennsylvania
    Good point! You'd also be consuming coolant. Check to see if your reservoir is full, or if it appears a suspiciously low.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    And as long as you have the plugs out, I would run a compression test. Most times the issue is the wiring harness.
    Dec 07 2024
    Vancouver
    So I pulled the plugs last night a boroscoped all of the cylinders, all plugs and pistons looked the same, no steam cleaning or ring wash on any of them. #2 spark plug had a bit more resistance when removing but it wasn't very hard to remove it. Don't have a compression tester but I could maybe get one for when I try my plug swap to test compression.
    I found Avantnoir's post about the injector wiring harness and rechecked my wiring this morning and I think that may be my issue, they are fairly crispy. Most have cracks in the insulation and tape wrapping them to hold the together. And the insulation is crumbling apart at the pins
    Dec 20 2024
    Arizona
    I belive you can rent one from auto zone or most local parts store
    Sep 10 2021
    Pennsylvania
    Replacing the harness looks like an intimidating job, but it's really not bad. Just take your time and do it right the second time.
    Dec 07 2024
    Vancouver
    Not to worried about the install, just wondering how I order 1 from Avantnoir?
    Sep 10 2021
    Pennsylvania
    PM him. He was the first one who responded to you above.
    May 22 2007
    Santa Monica CA
    Quote Originally Posted by Audicouver View Post
    Wiring most likely the source. Tape on it is a bandaid on a shotgun wound.
    Replacement Fuel Injection harness is $135 direct from me. Or $145 on ebay.
    May 22 2007
    Santa Monica CA
    And most likely, the coil pack wiring is shot.
    Dec 07 2024
    Vancouver
    PMed you AvantNoir. Maybe Ill just get both off of you if you have them available
    Dec 07 2024
    Vancouver
    So this morning I swapped spark plugs in cylinder 1 & 2 and monitored on my way to work. Misfire moved to cylinder 1, bingo! I realized they were NGK plugs so after work I got a set of 4 bosch plugs and changed them. Car wouldn't start... I swapped them all back and car still won't start. I'm guessing I somehow damaged the wiring to 1 of the connectors? Looking for insights.
    I noticed when I was removing the bosch plugs they felt pretty hot. Hoping I didn't damage my ecu..
    May 22 2007
    Santa Monica CA
    Yes, you probably damaged the wires on the coil pack harness. NGK plugs are good as long as they’re BKR7E gapped at no more than .028
    Dec 07 2024
    Vancouver
    So I ran a code check in vcds this morning and have a P0688 ECM power relay load circuit : open circuit code. Maybe this is my problem, I blew a fuse or the relay is dead. Wondering which fuses, relays and power to check to diagnose this?
    May 22 2007
    Santa Monica CA
    http://wiki.ross-tech.com/wiki/index...2/P0688/001672
    Usually wiring related.
    And check your DM's
    Dec 07 2024
    Vancouver
    Thanks AvantNoir
    Dec 07 2024
    Vancouver
    So after reading a few posts about my no start issue I went and picked up a pack of 20A fuses and pulled fuse #29 and sure enough it was blown. Replaced it and the car started right up. Going to keep extra fuses handy and keep driving the car and not touch anything until I get my replacement harnesses installed for the coils and injectors. And yes I will install 1 harness and then see how the car runs before installing the other so if I have any issues with either install I can narrow down if I messed anything up. Will post an update once I've done this.
    Dec 07 2024
    Vancouver
    Just an update, I've received my wiring harnesses, just waiting for some time to install them. Have also more recently had head issues that I've been dealing with as that is more important. A few weeks ago I cut all the boots off of the coil plugs and all of the insulation on the wires had disintegrated and thewires were corroded and shorting together. I carefully pulled them apart and isolated each 1 with electrical tape and since doing that I don't have any more misfires so that was definitely my issue. Will update again once I get the new harnesses installed.
    Dec 07 2024
    Vancouver
    Update: I got both wiring harnesses installed and my misfire issues have disappeared. Thanks Avantnoir for all your help, great harnesses and instructions!
    Sep 10 2021
    Pennsylvania
    Awesome! Thank you for the update as well. It's good to see to it that these threads get updated with the resolution.
    May 22 2007
    Santa Monica CA
    Another success story! Always glad to keep another B6 on the road!
    I have Avantnoir injector harnesses in both of my B6 Avants. Best replacement out there.
