Results 1 to 17 of 17
    Junior Member One Ring
    Dec 21 2022
    Central pa
    Allroad 2.7t mid muffler
    I’m looking for stock style mid muffler for my 2.7 Allroad. From what I can tell the c5 chassis mid mufflers look like they have the same mounting points and pipe configuration with slightly different diameter pipes. Any one have experience with the different mid mufflers? Could I use a muffler from a sedan a6 with the 3.0l? Appears the difference is the pipe diameter. Thanks
    Feb 05 2007
    Portland, OR
    According to this website that I use to reference parts diagrams, the 2.4-3.0 use the same mid and rear section exhaust parts, but there are multiple part numbers listed, so I bet there is a diameter variance. I do not know how to tell, but you could search all the part numbers individually and try to find some info there.
    https://audi.7zap.com/en/usa/audi+a6...id-253-253088/
    My other more practical thought is to search Marketplace for a part out and see if their exhaust is good. I did a quick search within 50 miles of Williamsburg, PA and found a bunch of Allroads for sale and a couple for
    Dec 21 2022
    Central pa
    That’s a great website for parts diagrams! Specs on the mufflers are hard to find but I’ve had a little success finding the specs on the different clamps used. Seems I currently have 2in pipe from the cats. 50mm clamps fit there. I found the clamps listed for the 3.0 engine are 55mm so about 2.25 in diameter on that one. Looks like the clamp listed for the 2.8 engine is listed as 42mm so about 1 5/8 diameter on that one. I wouldn’t mind picking up a parts car… but if the exhaust is worth saving the rest will probably be worth saving too then I’ll have another one like some other guys on here! Seriously I have too many horses in the stables as is!
    Dec 24 2012
    Maine
    I haven't had experience with the mid muffler, but I know that the flex coupler is 2.25 X 4.0 inches. This connects the down pipe to the catalytic converter. I suspect the diameter is the same coming out of the catalytic converter. Would the diameter be different going into the mid muffler? I also have the 2.7T engine in a 2003 allroad.
    David
    2003 Allroad 2.7T
    2015 Allroad 2.0 TFSI
    2001 Porsche Boxster S
    1970 Porsche 911E
    1979 BMW 320i
    Dec 21 2022
    Central pa
    Hmm interesting. I’m certain I used 2in flex couplers to repair my down pipe to cat connection. I definitely have 2 in behind the cats as well. Perhaps we have the different engine code 2.7t.
    Established Member Three Rings Avantly's Avatar
    Oct 02 2023
    Squirrels, Chickens, and then there's the mice :/
    "Pure Michigan"
    I have a pile of C5's from out west with original exhaust systems... Despite the total lack of moisture and salt out there I would be surprised if any of these cars have any component that could be reused if I removed them. They corrode from the inside due to the moisture in the exhaust, I think that corrosion may be worse than anything external! All of them show significant corrosion where the pipes are welded into the body of the muffler/resonator/etc. The center one looks the worst on the 2.7T cars, even my low mileage ones.
    Dec 24 2012
    Maine
    Quote Originally Posted by Blacka1vw View Post
    I supplied my welder with the 2.25X4 in. flex coupler. He made no mention of it being the wrong diameter. I wonder if he made it fit by sliding over the existing pipe? I actually didn't measure it myself so I don't know for sure what diameter pipe I have. Mine is a 2003 allroad with 2.7T engine. Interesting.
    David
    2003 Allroad 2.7T
    1970 Porsche 911E
    1979 BMW 320i
    Dec 21 2022
    Central pa
    Quote Originally Posted by Avantly View Post
    This is exactly what killed my system that I’m looking to replace.
    Feb 05 2007
    Portland, OR
    I’m naive to the Midwest corrosion issues. Sorry guys.
    Oct 02 2023
    "Pure Michigan"
    Quote Originally Posted by ShelbyM3 View Post
    Hello, yes my name is insane jealousy, is ShelbyM3 there? :D
    Feb 05 2007
    Portland, OR
    Doing a little exhaust work myself and the outside diameter (OD) of my factory 2003 Allroad 2.7T is 2.25” where it would meet the factory catalytic converters.
    Dec 21 2022
    Central pa
    I wonder if this difference in diameter goes along with the change from apb to bel engine? Mine is 01 apb engine stock downpipes.
    Feb 05 2007
    Portland, OR
    I don’t think so. Maybe 2001 because it’s special, but I’ve always been under the impression that all C5’s had the same exhaust from the catalytic converters back. At least here in The States. Clearly, there’s a diameter difference, but the APB to BEL changes were with the turbo exhaust flanges.
    Dec 21 2022
    Central pa
    I ended up finding a good price for a mid muffler from a b5 a4 with the v6 engine. It appeared very similar to my stock one with the inlet pipe configuration a bit different for the a4. I was able to cut the inlet pipes and weld my x section off my old muffler. I thought the hanger looked closer to my old muffler but they were spaced a little different. I just saved the old ones and welded them onto the new muffler body. Took a little work to get it all perfect but the final result is good. As for the rest Im gonna have a shop bend me tail pipes and utilize the original stainless tips. It sounds fine with this setup so far. I’d say the piggie pipes had the most affect on the sound so far.
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    don't like noisy exhausts, but it may help to spin turbos couple hundred RPM earlier, so should be noticeable when driving.
    Dec 21 2022
    Central pa
    Quote Originally Posted by V1nny View Post
    I very much agree! I didn’t want any extra noise. Without any tailpipes it’s only a little louder than it was with the original center and rear mufflers in place. Unfortunately my rear mufflers are all about gone now too.
    Feb 05 2007
    Portland, OR
    Heck yeah! Nice find and way to be resourceful! I bet it sounds really nice. I know this sound, haha.
