Results 1 to 5 of 5
    Junior Member Two Rings
    Nov 19 2024
    Minnesota
    Smoke out vents. 8 hours later dash lit up like a Christmas tree and wont drive? WTF?
    I've got a 2008 S5 and just last night the car crapped out on me after white smoke started pouring out of the vents (for heat and ac) that are underneath the front seats. At the time the car was running well with no issues idling or with power delivery despite smoke billowing out of the vents. I quickly turned off the car and checked for fires or smoke in the engine bay, or just strange smells on the outside of the car and didn't find or smell much of anything. The smoke smelled a bit like burning rubber but I don't know how accurate that description is because its hard to describe the smell. I have smelled the same smell before when driving the car (never noticed smoke and it was never as strong as it was yesterday) usually when/after accelerating and I just assumed I was smelling clutch because that's what made sense to me. Anyways, I let the car sit for 8 hours while I was at work thinking the car would be fine and that I just need a new clutch but when I started it up, the dash lit up like a Christmas tree saying there was all sorts of faults. (the ones I remember were electronic ebrake fault, traction control fault, abs fault, and a few other things that I cant remember) The EPC light was on and when I pulled the codes I got 2 engine control unit codes. P2101 (Throttle actuator control (TAC) motor - range/performance problem), and P2106 (TAC system - forced limited power mode). I figured I could limp the car home but I couldn't even pull out of the parking spot without it almost stalling 3 or 4 times. Even when I was just sitting there the car couldn't find idle and was barely able to stay running.
    I have been trying to figure out what could have possibly gone wrong all at once to make these issues appear so quickly and but haven't been able to think of anything that could have caused all my issues.
    Like I said, I thought the smoke was from my clutch and that I had just burned the crap out of it but that doesn't make sense because the car would still run fine.
    The next thing I thought is that because my battery is on its last legs, the car was sending to much power to charge the battery and some of the wires ended up overheating and started to smoke. This could explain the rough idle also since its possible the battery was not able to provide enough voltage to computer systems after the wires fried themselves which may have left many sensors and systems confused causing the symptoms in the engine and the many lights on the dash. This still does not make sense because the smoke did not smell like electrical fire at all.
    I also considered it could be coolant that leaked into my heater core and started burning but I don't think this would cause my engine problems and like I said earlier, I occasionally have smelled the same burning smell while driving but have never noticed a coolant leak/burn ever and the coolant level has always stayed the same.
    I'm looking for any help you have to offer, including information, theories, things to check. I'm also more than happy to provide more details if requested as well as run any tests or checks to get you the information you need to help me out. I will be active on this forum and will gather more details and update you with them as I find them. literally anything helps. Thanks!
    Veteran Member Three Rings Mrads's Avatar
    Dec 20 2012
    '13 Daytona RS5, '14 Subaru Outback (wife's DD)
    New Westminster, BC, Canada
    What you are describing is fairly similar to what I experienced, in my B8 S5, when the power relays fried themselves.
    Sent from my Pixel 8 Pro using Tapatalk
    Nov 19 2024
    Minnesota
    Thanks for the input. Ill check the relays. If it is the relays I find it interesting that the smoke didn't smell like electrical fire. What did it smell like when your relays blew? Did your car still start? Any more symptoms?
    Dec 20 2012
    Quote Originally Posted by Willi_must View Post
    Sorry for the delay.
    Hard to describe the smell I had when it happened. The power relays are encased in an insulator that when it gets exposed to heat does really smell like rubber.
    No, my car would not start. It would turn over but wouldn't start. The dash was a xmas tree of cascading failures.
    Nov 19 2024
    Minnesota
    Thanks for the replies. I did actually get the car back on the road a few days after I got it towed but we don't know why it all of a sudden started working again. since the time we got it towed till when the car started working we did 2 things. Charge the battery and replace a random power relay just because it was cheap enough and wasn't too much work. We replaced the main power relay but we are pretty sure it was fine before we replaced it so that shouldn't have done anything. After that the car ran just fine for about 2 weeks. now its doing the same thing again and we cant figure out what went wrong.
