2013 B8 allroad, 155k miles, 2.0t, auto transmission
Issue:
Drivetrain vibration over the past few years, got worse in the past few months, recent work of replacing the engine mounts, front axles, and tire balance did not completely fix the problem. Should my next move be replacing the front control arm bushings/hardware? While driving the vibration can be inconsistent, but it’s pretty regular when accelerating, and it’s definitely always there when idling in drive with a foot on the brake, and goes away in neutral. Any thoughts on the control arms role in this?
History:
It started about two years ago with a local tire/oil change shop replacing front axles due to ruptured boots. I believe they went through three sets of axles and I eventually settled for a set that wouldn't cause a noticeable vibration under load, but the car still didn't feel perfect. Drove for about two years without much change but then the vibration started to get worse, and could be felt regardless of speed or loading, even when stationary in D with a foot on the brake. Shifting into N while stopped or moving would cause it to disappear. By the time I recently brought it to a better import shop the vibration had gotten pretty bad.
Recent work:
New axles (boots were torn), replaced the engine mounts (old ones were shot), balanced and rotated the tires, oil change, state inspection, etc. After the work the vibration was much less noticeable but definitely still there. The shop acknowledged that it's still there, and replaced the new right front axle at no charge, but with no result. The transmission mounts or fluids have not been replaced or serviced recently.
Currently:
On the highway it almost feels like an unbalanced wheel, but sharper, and it's there regardless of speed. It gets worse when accelerating, but is inconsistent (if I jump on it, sometimes I'll get a pretty severe wobble, other times not). While stopped, it completely goes away in N. On a cold morning it vibrates in park, and when physically touching the tires, it's definitely more noticeable in the front left. The vibration in park seems to go away after warming up.
Thanks very much!
