    Nov 13 2009
    the OC, SOCAL
    heavy oil consumption q3 2016
    so im approaching 100k miles.
    q3 2016
    stock
    no mods.
    starting to have oil very heavy oil consumption. not sure exactly what is causing it or the fix.
    anyone else having this issue and remedies?
    also any way to tests for causes?
    May 20 2010
    PCV?
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Nov 13 2009
    the OC, SOCAL
    changed the pcv with an oem unit. still has the same issue. no change.
    Established Member Two Rings Victor_B7's Avatar
    Mar 14 2019
    Vancouver WA
    Same issue here. Car is getting diagnosed. My best guess is piston rings. Common issue on our cars.
    Nov 13 2009
    the OC, SOCAL
    me too. piston rings might be the issue.
    so far I have kept an eye on levels. it seems intermitted.
    I'm check per week now. used to be days.
    days didn't change all that much till the 7 to 10 day.
    so now I check ever week.
    noticed some weeks it does drop a whole line. from top filled line to low level line. after 7 days.
    some weeks nothing really changed. not sure the cause or what.
