Results 1 to 38 of 38
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    C7 S6/S7 DL501 DSG to ZF8 HP55 Transmission Swap Guide
    ZF8 HP55A Transmission Swap Audi C7 S6/S7 – A Complete Guide
    This guide provides a detailed and organized overview of how I replaced the factory DL501 transmission with a ZF8HP in my 2013+ Audi C7 S6/S7. As of today the car runs and drives great. The overall experience is much better and this is now what I consider the best mod I have done to the car.
    Introduction
    First off, I’ll say this swap has been quite a journey. I learned a lot about things I was previously unfamiliar with and gained a much deeper understanding of my car and how it works. I’m glad I took on this project because it allowed me to do something different with my build while also helping others make this swap feasible. For anyone that does it after me, it will be simple. This has been a hot topic in the community for a while, many people saying or implying that it could not be done. Not only did I set out to prove it can be done, I am here to prove that anyone can do it and it will not cost a leg or an arm. In fact, it is cheaper than replacing a DSG clutch and way cheaper than replacing a DSG. We will not get too into the WHY, but we will address the HOW.
    I will not detail the removal or installation of the transmission itself—there are manuals and videos for that. Instead, I’ll cover the hardware, wiring, coding, immobilizer management, and essential tools, along with tips on where to get ODIS and how to adapt everything. I am not a mechanic.
    Hardware Requirements
    The hardware part of this swap is fairly straightforward compared to many other transmission swaps. Essentially, you remove S6/S7 parts and replace them with A6/A7 parts. Everything bolts right up—no custom adapters or tunnel hammering required—making it "simple" compared to other transmission swaps. Unlike nearly other ZF8 Swap, we do NOT need to use a standalone TCM such as the Turbolamik ($2500) If you see what some people go through to put ZF8 transmissions in other cars, you would agree we have it easy.
    Parts List
    - Transmission: ZF8HP55 (Any variant from C7/C7.5 or D4/D4.5; match your generation to minimize coding issues. My transmission A6 transmission I selected is NNT code.( It does not matter what code your DSG DL501 was, it will work on any of them)
    - Rear Differential: A6 (Part Number OBC500044D)
    - Rear Axles: Non-sport axles if switching to a non-sport differential (Part Number 8R0501203C) IF you already have Non-sport diff you will keep your diff and rear axles.
    - Shifter Cable: 4G0713265T or 4G1713105D (with assembly)
    - Transmission Mount Bracket: 40399115G
    - Transmission Crossmember: 40399263G
    - Torque Converter: RS7 or TDI (optional but highly recommended if you’re using an A6 transmission) ~ this will turn your A6/A7 transmission into an RS transmission
    SPECIAL NOTE: TRANSCOOLER - YOU WILL NEED TO GET A TRANSCOOLER, I USED AN AFTERMARKET COOLER. YOU CANNOT USE YOUR S6/S7 TRANSMISSION COOLER THE BRACKET WILL NOT MOUNT UP. YOU CAN GET A6/A7 TRANSMISSION COOLER AND LINES.
    Additional Hardware Notes
    - You must swap and add a few bellhousing bolts:
    - 1 × M10 100 mm bolt on the bottom where there is an extra hole.
    - 2 × M10 60 mm bolts to replace where your original bolts are too short.
    Take a look at this picture of DSG VS ZF8 bellhousing bolt locations for reference
    ZF8
    DSG
    Tools Required
    - Strong Battery Charger/Maintainer (Always keep this connected while reading/flashing)
    - ODIS Engineering (ODIS-E) and ODIS Service (ODIS-S), with GEKO account or dealer/shop access
    - VCDS (VAG-COM) for user-friendly coding and diagnostics
    - ODIS Compatible Flash Cable (for example, VNCI 6154A or Mongoose JLR Pro/Clone) (Tactrix Openport will not work)
    - VAG style wire depinning tool (can be found on Amazon)
    -DS1 ~ though it can be done without, it is more complicated without it
    Wiring Adjustments
    You must repin the DL501 transmission connector to match the ZF8HP layout. Correct pin assignment ensures the TCU can communicate properly with the transmission.
    Pinout for 2013 Audi S6 Using A6/A7 Transmission Code NNT
    Pin Wire Color
    1 Blue/Black
    2 Blue/Grey
    5 Orange/Black
    6 Orange/Grey
    8 Green/Purple
    9 Black/Purple
    11 Grey/White
    13 Red/Grey
    14 Brown
    15 Green/Yellow
    Unused Wires
    Brown/Grey
    Red
    Green
    Note: Wire colors may vary by model year or region. Double-check your wiring diagram or verify continuity to confirm where each wire goes. Comment below if you need help.
    Helpful Resource
    YouTube Video:
    https://www.youtube.com/watch?v=GRNb2nNMf0M
    (This explains the transmission connector repinning process in detail.)
    Immobilizer Management
    These cars run on Immo V/BCM2, so you must ensure your new transmission TCU and the ECU/cluster are aligned. If your powerclass does not match, or if you have physically changed control modules (such as the transmission), you will need to adapt or disable the immobilizer:
    1. Adaptation with ODIS Service
    - Use ODIS-S with a valid GEKO account to adapt the TCU, immobilizer, and cluster if necessary.
    2. Alternative Solutions
    - An emulator, such as those from abitres or a VAG-TCU Immobilizer Emulator(physical), can bypass the immobilizer.
    - Some tuners or services can do Immo-Off or IMMO TRANSFER using your DL501 EEPROM data on the AL551, although those appear less common. ODIS adaptation is generally easiest to get ahold of for the average joe.
    Why Powerclass Matters
    Powerclass is part of the immobilizer handshake. If the ecu powerclass and the powerclass the immo is looking for do not match, you will trip the ECU immobilizer. For example, flashing RS7 software onto an S6 ECU sets powerclass to RS7. Unless you manually match it to the S6 BCM, you will have an immobilizer conflict. If you are using my modified file, powerclass is already matched to C7 CEUC engine which is what the immo handshake is looking for.
    Swap Process
    1. ECU Flash
    - Contact DS1 and provide your DS1 serial number, explaining that you will not change your ECU hardware but need an RS7 bin.
    - DS1 will supply a stock RS7 file (e.g., 4G0906560B__0008 for a C7 RS7).
    - Full Flash the stock RS7 file, then cal flash the modified RS7 bin from the attached folder. This modified file already has powerclass and IMMO settings adjusted but is otherwise stock.
    - Before driving, copy over any needed (MAP SENSORS. SOI, FUEL IGNITION TABLES) tables from your old S6/S7 tune using TunerPro. Open two instances of TunerPro since the XDFs differ between files.
    - Refer to other sections (e.g., VCDS) to confirm coding and clear any codes.
    2. Repin the transmission connector (see Wiring Adjustments). then plug it into the transmission
    - Flash the TCU with an RS6/RS7 .frf file. If you have the RS (RS6/RS7) transmission, skip this step.
    - For details on obtaining ODIS-E, see the “Where to Get ODIS” section.
    How To Flash Transmission with ODIS E Video
    3. Adapt the Immobilizer with ODIS-S
    - See “Immobilizer Management” (above) for details on matching the TCU and ECU with your cluster/BCM2.
    - If you lack a local shop or dealership, refer to “Where to Get ODIS” for info on buying ODIS-S plus a server login.
    - Complete the online GEKO procedures to link the new TCU and ensure no immobilizer conflicts remain.
    - IF YOU ARE USING RS TRANSMISSION YOU ONLY NEED TO DO ECU FLASH AND ADAPT THE IMMOBILIZER THEN PROCEED TO THE VCDS SECTION.
    - Make sure you have all of your vehicles programmed keys with you for the Immobilizer adaptation process.
    How to Locate Immobilizer Adaptation and SVM in Odis Service Video
    4. Scan with VCDS and Apply Correct Long Coding
    - Once you have flashed and adapted components, perform an Auto-Scan (see the upcoming VCDS Section) and address any faults.
    - Paste correct long coding if a module appears uninitialized (The long coding for the module is showing all 0's). When prompted, click Yes to use default values.
    - Clear remaining fault codes and confirm everything is coded properly.
    5. Start and Warm Up
    - After major faults are cleared, start the car and let it warm to operating temperature.
    - Check and correct transmission fluid levels. Refer to hardware or standard ZF8 service guides for fluid procedures.
    - Perform transmission adaptations (via VCDS or ODIS) for the best shifting results.
    6. TCU Tune
    - After confirming the car drives well, choose a tcu tuner and flash a tcu tune that suits your modded vehicles power levels.
    VCDS Section
    You will use VCDS (VAG-COM) throughout the swap to verify functions, read/clear fault codes, and confirm final coding:
    - Perform an Auto-Scan to detect modules and fault codes. Click "Autoscan"
    - Click the "Gateway Installation List" to confirm which modules are present.
    -Double click on any red or problem modules to open and review them.
    *****Uninitialized Module Message
    If, after flashing the ECU or TCU, VCDS indicates a module is uninitialized (all zeros showing for coding), you must re-insert or paste the proper coding:
    - For ECU/TCU/ABS coding, you can try using my provided long coding if you have a C7 with air suspension and sport diff removed. Adjust if needed.
    -- For non-ECU/TCU/ABS modules, use your original coding from a previous Auto-Scan.
    Long Coding
    Below is what worked for my C7 Audi S6 (with air suspension and no sport diff). If you see errors like “Module Incorrectly Coded,” you may need to tweak these (comment below for help):
    Engine Coding: 1A2A003265460A0E1000
    Auto Transmission Coding: 000001
    ABS Coding: 65A64F01A665F2805B00
    For the ABS module you must click Security access then wait for the bubble to pop up and enter the alternative coding password mine was S11820 then you can go to coding and paste the coding and it should accept.
    Special Note:
    Currently, my engine module shows the following code, which does not affect operation:
    4715 - No Communication with Instrument Cluster
    U0155 00 [00100111] - -
    [Lost Communication With Instrument Panel Cluster (IPC) Control Module]
    Not Confirmed - Tested Since Memory Clear
    I plan to resolve this using SVM in ODIS-S on the Instrument and Engine modules. If that does not work, the code can be masked or disabled in the tune. It has not caused any issues or effects on driving.The instrument cluster also communicates and operates fine.
    Let me clarify : If you follow this swap process correctly you will have NO swap-related error codes on the dash at all. If you do see any codes other than this one i mentioned then comment below for help. This will be a clean, proper swap.
    Deleting the Sport Diff
    If your original car was equipped with the sport diff but you have now installed a non-sport rear diff, you’ll need to delete the sport diff in VCDS:
    Sport diff delete:
    1. With no errors (sometimes errors work just depends on your VCDS) go into instruments module - coding - uncheck sport differential installed
    2. Turn off car, turn back on and verify no dash errors. If so continue.
    3. Go into canbus module - gateway list - remove AWD.
    4. Restart car, if no dash errors continue.
    5. Go into the rear of the car and remove the Fuse for ONLY the sport diff (cars might vary in fuse check diagrams). Verify no errors on dash. If so your good to remove the diff wiring/and or diff.
    6. DO NOT REMOVE THE AWD MODULE OR UNPLUG
    For more information, see this TGK Motorsports YouTube video discussing the sport diff delete process:
    https://www.youtube.com/watch?v=T6rFej3PY9c
    Enabling Paddle Shifters / Tiptronic
    1. Enable Shift by Wire
    - In VCDS, go to Select Control Module, then ACC/Auth, then Coding, then Long Coding Helper.
    - Find Shift by Wire and check it.
    - Close the Long Coding Helper. Click Do It to confirm.
    2. Activate Steering Wheel Tiptronic
    - In VCDS, go to Transmission, then Adaptation.
    - Look for the channel Steering Wheel Tiptronic and set it to Active.
    - Repeat for any other features, such as gear display, that you want active.
    Make sure all three connectors on your gear selector assembly are plugged in. If you only have two connected, you are missing one.
    Where to Get ODIS
    - ODIS-E (Engineering) can be purchased cheaply from sites like OBDII365 (FOR FLASHING)
    - ODIS-S (Service): (FOR SVM/IMMOBILIZER ADAPTATION)
    - You can ask a local VW/Audi dealership or specialized VAG shop that has a GEKO account to do the required adaptations for you
    - You can also purchase the software and one-time logins from various sellers on aliexpress. Some will charge around 40 dollars for ODIS-S installation plus $40-$60 dollars for a one-time server login.
    - There is also another popular website for this https://www.vw-geko.com/
    - Be sure to confirm that Audi is active (for immobilizer and component protection services) before paying for any logins or scheduling adaptations. You can check the status here or on their WhatsApp https://status.vw-geko.com/
    Use these services at your own risk. In SOME cases, someone will remote into your computer to do the login. If you are purchasing from AliExpress you do have the ability to dispute if there is an issue. Make sure that you inquire and confirm immobilizer adaptation is active/available before purchasing.
    TRANSMISSION TUNING
    - I opted to tune my transmission using HPTuners, which offers a user-friendly solution for ZF8 transmissions. (This is only if you know wtf you're doing or know someone that does)
    - You could also choose from one of the well-known ZF8 TCU tuners (e.g., JHM, ETSpec) to get a TCU tune.
    - Ultimately, if your car is highly modified, you will need a TCU tune. The stock TCU expects certain RPM and torque limits, so exceeding them can trigger transmission codes or a “Transmission Malfunction” warning. This doesn’t harm anything; but it will make you shit bricks if you didnt know that it just means you need a TCU tune that accommodates higher rev limits and torque levels or to adjust your ecu tune accordingly. If you happen to be running below stock RS6/RS7 power levels and using stock rev limit you technically dont need a transmission tune yet.
    IF YOU HAVE A C7.5 YOU CANNOT USE MY FILES
    YOU WILL NEED TO SOURCE A TCU FILE THAT MATCHES THE GENERATION OF YOUR TRANSMISSION AND AN ECU FILE THAT IS C7.5 RS7 AND MODIFY THE POWERCLASS TO C7.5 S6/S7 ACCORDINGLY.
    File Overview:
    Download Link
    MED17_1_1_ C7 RS7 STOCK 0008 IMMOFFPC41.bin - FLASH THIS TO YOUR ECU (CAL FLASH WITH DS1)
    FL_4G0927158BD_1007.frf - FLASH THIS TO YOUR TCU USING ODIS-E AND YOUR ODIS COMPATIBLE CABLE (ONLY IF YOU ARE USING A6/A7 TRANSMISSION) THIS IS A C7 RS6 STOCK FILE
    ZF8SWAP.TXT - THIS GUIDE IN PLAINTEXT FORMAT READ IT IF YOU GET LOST
    Costs
    Below is what I spent while trying to keep this swap budget-friendly. Your total may differ based on availability, upgrades, or professional assistance:
    Item Cost
    ZF8HP55 Transmission (NNT Code) 400
    Torque Converter (RS7 or TDI) 300
    A6 Shift Assembly 70
    A6 Transmission Mount 60
    A6 Cross Brace 100
    A6 Rear Differential 160
    A6 Rear Axles 100
    Miscellaneous (Tools/Fluids) 1000
    Total $2190
    Disclaimer
    The costs and methods listed here reflect my personal experience completing this swap. Your expenses and approach may vary. This guide is for informational purposes only, and you should follow all relevant safety precautions, consult with professionals where needed, and verify the compatibility of parts before undertaking any modifications. I am not responsible for any issues that may arise from performing this swap.
    Dynospectrum does not endorse or support this transmission swap in any capacity. Please do not contact them for assistance with the swap. They specialize in ECU flashing software, not transmission or engine swap support. That said, they were extremely helpful with the ECU side of this project. As always, everything you do to your car is at your own risk.
    Credits
    This project would not have been possible without the assistance and insights from the following individuals and resources:
    - QCrazy
    - Audiquattro44
    - PRJ
    - Dynospectrum
    - Christian O
    - 813garage
    - FE Performance
    - Artemesia
    - Projectlsaudia4
    - Sleepertuned
    - MWELL
    - TGK Motorsports
    - Shane Horning
    - AudiNeil
    Thank you to every one who helped in any way big or small. With the right tools, patience, and know-how, a ZF8 swap can transform an Audi C7 S6/S7 into a much more reliable and durable animal.
    IF you appreciated this swap guide follow me on instagram @stolens6
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Awesome write-up!
    Jun 28 2019
    California
    Quote Originally Posted by Jake@JHM View Post
    Awesome write-up!
    Thank you!! It took me some time but I wanted to get something out for people that are looking to do this swap in the near future.
    IG:@stolens6
    Jul 28 2017
    Oklahoma City
    Ooooohhhhh YEAH!
    Active Member One Ring vhturbo11's Avatar
    Mar 25 2019
    '88 Escort GT (2JZGTE swap) /'65 C10 Custom LB
    Martinsburg/WV
    Great write up!!!!
    Sent from my SM-S928U1 using Audizine Forum mobile app
    Junior Member Two Rings
    Sep 04 2018
    Atlanta, GA
    Thank you so much for taking the time to document this swap. In this day and age very few people bother to document things outside facebook groups, etc. Great info.
    Current:
    2013 S6 DS1 tuned: SRM +4 turbos, downpipes, etc
    1995 UrS6 Avant: Euro bumpers, forged internals, EFR6758, KW coilovers, ec
    997 Carrera
    Past: UrS6 x4, RS6 manual swapped, B8.5 S5, other dumb cars
    Jun 27 2024
    Nashville, TN
    Nice write up. This will go a long way for the community.
    Aug 19 2022
    Idaho
    Excellent work bellybutton! The ZF8 is arguably the greatest TC automatic transmission in automotive history, pairs beautifully with the EA824.
    2013 S8 | TS1 turbos | TS Actuators | 4 BAR MAP sensors | SRM A2A | SRM 3” intakes | Redstar 3” downpipes | SRM flex fuel kit | Autotech HPFPs | lowered 15 mm | JHM oil filter relocation | 22 x 10.5 Verde Axis v99 wheels | Integrated Escort laser radar | PFA throttle inlets | bTres | KyleTunedit TCU / ECU
    Jun 28 2019
    California
    Thank you for the kind words everyone I'm glad to be able to give back to the community that has helped me out a lot. I do agree that the ZF8 and the 4.0t are a match made in heaven. It feels like this is the transmission that belongs in the car
    edit: I'm excited to see how far this platform can go with the ZF8, the D4/D4.5 has had us beat for a while with the ZF. I know of a handful of cars faster than mine that will be doing the swap as well.
    IG:@stolens6
    Veteran Member Four Rings Shane Horning's Avatar
    Nov 16 2018
    2012 A6 Prestige IE dual pulley. custom trans tune. mercracing hx. autotech hpfp.
    Upstate. New York.
    Great writeup! Just received odis e and s thru a uk company. Will start playing with it however idk if it is the version that will work with the immobilizer adaptation. Thanks for sharing!
    Sent from my SM-S921U using Audizine Forum mobile app
    Jun 28 2019
    California
    Quote Originally Posted by Shane Horning View Post
    ODIS S V23 will work for immobilizer adaptation if you catch https://status.vw-geko.com/ at a time where its online for immobilizer, theirs is super convenient. But if not, then you will need ODIS S v24 and your best bet is the aliexpress/whatsapp sellers for this most of them will sell you the software and the login at once thats what I did for mine.
    IG:@stolens6
    Established Member Two Rings NorthernGTI's Avatar
    Oct 19 2024
    C7 TDI
    Mississauga, Canada
    Whats the difference between TDI torque converter and a regular A6?
    2014 TDI
    Jun 28 2019
    California
    Quote Originally Posted by NorthernGTI View Post
    The TDI torque converter is designed to handle more low end torque for the diesel models
    IG:@stolens6
    Oct 19 2024
    C7 TDI
    Mississauga, Canada
    Quote Originally Posted by Audibellybutton View Post
    Shit, Im so dumb. I didnt even think of that.
    2014 TDI
    Jun 28 2019
    California
    No worries, that was news to me not long ago as well lol
    IG:@stolens6
    Dec 25 2016
    Austin, TX
    Do you have to do the Sport Diff delete?
    Jun 28 2019
    California
    Quote Originally Posted by blubaru View Post
    No but if you dont then you will have to pair it with a trans that has "torque vectoring" aka was designed to be paired with sport diff
    IG:@stolens6
    Dec 04 2018
    Mesa AZ
    I was just about to change my clutch and deal with mechatronics issues but this looks so much more appealing.
    Dec 25 2016
    Austin, TX
    Quote Originally Posted by DTHS7AR View Post
    Same - well for me it’s flywheel and possibly flex plate, maybe clutch because it’s all coming apart anyway. I’m C7.5 so I wonder if there are any surprises for the swap?
    Jun 28 2019
    California
    I want to update that this swap is also working for C7.5 If you have any questions let me know. I will update the post soon with C7.5 stuff but its literally the same process.
    IG:@stolens6
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    So you need software and a dongle for this avenue, right? Are there faux dongles like the VCDS ones? Any particular AE Store or Seller you can recommend?
    Cheers,
    KS
    Dec 25 2016
    Austin, TX
    I have sport diff - in theory the A8L, S8, and RS7 transmissions offered torque vectoring so these might be compatible but I’m wondering if there would be additional steps to get it to work. There are also many different transmission 3 letter codes and not much explanation, I’m working on creating a spreadsheet to map out all the compatible part numbers.
    ODIS is going to be the deal breaker for me, I’m going to call some local shops to see if they would entertain helping with the coding but I imagine that could get costly quick.
    Jul 26 2018
    Humidity, NC
    That's why I'm thinking that a small investment in ODIS Software and cabling now, could pay off in the future, not only for this project, but for others (module swaps and the like).
    Cheers,
    KS
    Dec 25 2016
    Austin, TX
    Quote Originally Posted by Botbasher View Post
    Cheers,
    KS
    I guess it would depend what the all-in cost would be, for the cable and various softwares needed. It would be really cool if there was a legit way to do the remote access for cheap.
    Jun 28 2019
    California
    If they have it. It should not cost more than 1 hr of labor. If they dont itll not cost you more than a few hundred to get everything you need.
    At the end of the day, ive seen so many people rebuild mechs or replace clutches and still have issues.Many people do not understand the dsg and will just throw money at it. This is why I went this route
    IG:@stolens6
    Jun 28 2019
    California
    Cheers,
    KS
    yes there are clones that work. but theres not any that I recommend specifically, you are free to try as they are often much cheaper but they are also hit or miss. If you have questions about a specific odis cable rec PM me,
    IG:@stolens6
    Jun 28 2019
    California
    A note about the differential -
    I dont feel like i lost anything going from sport to non sport, truthfully I barely notice the difference even after I always wanted it when I had an A7.
    I noticed the Non-sport axles are definitely beefier than the sport axles. The non sport differential is actually much lighter than the sport diff while also more durable so those are some pros that make me not miss the sport diff.
    -EDIT
    I would like to add that when swapping out your sport diff it would be a GREAT time to get a JXB LSD https://www.jxbperformance.com/produ...5-and-c7-s6/s7
    Unfortunately it wasnt in the budget for me at the time of the swap but I will get one down the road.
    IG:@stolens6
    Junior Member One Ring Ramaloce's Avatar
    Dec 21 2023
    Atlanta, GA
    Awesome write up! Been looking at doing this recently as I just found the limits of the stock clutch.
    Question - is there anything in the coding/conversion that would cause the car to fail an emissions test? I don’t really see how it would but a shop that’s local to me was concerned about it being a possibility. They didn’t say it would, just didn’t know one way or the other. Only way I could see it being a possibility would be if for some reason having an RS file in the ECU won’t let their emissions machine talk to the car. Thanks
    Jun 28 2019
    California
    Quote Originally Posted by Ramaloce View Post
    I cant give a definitive answer, for Georgia most likely no it wont fail. The jury is still out for CA. I'm not sure if it will, it might. They are much more stringent than other states.
    IG:@stolens6
    Jun 28 2019
    California
    2 Months Later Quick Update
    This was a great decision, it is still in my opinion the best mod I have done to this car. I will probably keep this car forever now. Earlier I stated I barely notice the difference between non-sport and sport diff, but I definitely do. I liked the sport diff better, but the difference isnt big. The transmission is really snappy and efficient. There has been no signs of this high mileage A6 transmission not being able to handle what I throw at it whatsoever. It handles it very well. IDK if it is the upgrade tq converter or the trans itself at work but it handles everything I can throw at it and could probably handle much more. I do not miss the DSG at all. Even though it was a great transmission itself
    IG:@stolens6
    Jul 26 2018
    Humidity, NC
    Are the diff ratios an issue between the the sport diff and the slush box?
    Makes the job a little easier if you truly only have to worry about the single component coding!!
    Cheers,
    KS
    Jun 28 2019
    California
    Cheers,
    KS
    yup the diff ratios is why we cant run the sport diff unless we get a trans that was paired with one
    IG:@stolens6
    Sep 24 2019
    Virginia
    Are you sure that's correct? Asking because while looking at parts interchanges, say a 2016 A6 3.0 gas for example, it only lists one trans code which is a PPD. It lists multiple different diffs, but the only sport diff listed is MKV while the equivalent sport diff on a DSG car is MKU. This makes me think the trans gear ratio stays consistent on either ZF or DSG and its the diff that needs to be catered to it (IE as long as you get a diff from a gas ZF car, you're good. The SSP says the TDI diff is wider). Jay from JXB also seemed to suggest this when we were chatting after I snapped the gears in my sport diff.
    Jun 28 2019
    California
    Quote Originally Posted by need2blower View Post
    I can give you my basis, what I found and what led me to that statement but if you find it to be untrue let me know and I will update it. But basically when researching I did find that all transmissions with sport diff (torque vectoring) were coded different, and the diffs that accompanied them were as well. I also confirmed that the gear ratio from the dsg cars and ZF8 is 100% different. Now whether or not a sport differential from s6/s7 is compatible with ZF from non sport car, I cannot confirm or deny. I dont know if they are compatible. Just that they are different. Please let me know if you do find more info about this
    IG:@stolens6
    Sep 24 2019
    Virginia
    I should have worded my response better...I 100% can confirm the ZF and DSG are different final drive ratios. Coding aside, I believe any diff that originally came on a gas ZF car will physically work with the swap. Whereas a diff from a DSG car would have some serious drivetrain bind for a short while before something exploded. I will check further and confirm if I find anything definitive. I do appreciate the swap guide, it has 100% given me the confidence to do the swap instead of paying damn near the same just to do the clutches I need.
    Jun 28 2019
    California
    Awesome I'm glad to hear that. I can promise you will not regret it one bit and I'm always here if you have any questions. Good luck on your build
    IG:@stolens6
    Mar 15 2025
    Maiden, nc
    Huh, well… I’m too far into the dsg parts now to do this, have a rebuilt mechatronics from GPO, their stage 2 clutch, and a billet flex plate ready to go in, just finishing up the a2a intercooler install, and swapping to srm upgraded exhaust manifolds, and rs7 turbos, srm intakes… and changing to a ds1 enhanced ots tune from c4, and the srm tcu tune once I get everything back together it’ll be off to the shop for the transmission issue(s)
    Jun 28 2019
    California
    Quick reminder,
    if you guys need help with your swaps please comment here. Its better than DM on instagram as I often dont see them. Also anything you need help with can also serve as public record in case any future forum lurkers encounter the issue later on.
    Also C7.5 ZF8 swap is definitely working and the process is the same. I have not updated the original post yet, I will when I have time. But do not let the .5 stop you from achieving greatness
    IG:@stolens6
