Results 1 to 10 of 10
    May 09 2012
    Virginia
    WTB: Belly pan for A[emoji6]
    Looking for a belly pan for my V[emoji6] A[emoji6] avant. There are , primarily looking for the front one but if you have both I’d be interested. Thanks.
    Sent from my iPhone using ]][emoji[emoji6]][emoji6][emoji[emoji6]][emoji6]]Audizine
    Mar 03 2014
    Northern Virginia
    You looking for OEM? Those would be tough to find. I found both aftermarket front and back on ebay, plus the metal bar to connect them both, but mine is an S6.
    2016 S4 Premium Plus - Daytona Gray - 6-speed
    2003 S6 Avant - Night Blue, 1 of 2
    2012 A4 Prestige S-Line Plus - Monsoon Gray - 6-speed, Sold
    2009 Chevy Cobalt SS Turbo - 5-speed, Sold
    1970 El Camino 350ci - 4-speed
    May 09 2012
    Virginia
    Quote Originally Posted by svt;[emoji637
    [emoji6][emoji[emoji6][emoji6]][emoji[emoji6][emoji6]][emoji[emoji6]][emoji[emoji6][emoji6]]]You looking for OEM? Those would be tough to find. I found both aftermarket front and back on ebay, plus the metal bar to connect them both, but mine is an S[emoji6].
    Ideally OE. I recognize it will be hard to find and probably used. Which if it’s in decent shape I’m fine with. I’ve seen the aftermarket ones. I’m guessing I’ll end up with one of those. The S[emoji6] configuration is different o believe. Thanks.
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    I may give away moderately used aftermarket allroad belly pan in a week or two, pickup in Arlington VA
    it is made from thin polyethylene, but better than nothing.
    Junior Member One Ring
    Jan 08 2017
    URS6, BMW E36, VW Touareg V10
    Western PA
    I have a brand new front belly pan for a 2.7 that I will sell. I'm located just north-west of Cumberland, MD - not sure where in Virginia you are located - I would not want to ship this for sure.
    May 09 2012
    Virginia
    Thanks fellas. I ended up with a cheap aftermarket one.
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Portland, OR
    Quote Originally Posted by jbain2 View Post
    Is it worth it? I need one and was looking at used units from Wolf Autoparts.
    Mar 03 2014
    Northern Virginia
    Apparently the front, large belly pan won't fit with the Hotchkis sway bar installed?
    Dec 04 2012
    Arlington VA
    I had stock belly pan with with the Hotchkis sway bar installed on 01 Allroad
    Feb 05 2007
    Portland, OR
    Quote Originally Posted by V1nny View Post
    Same. It’s a really snug fit, but I robbed the belly pan off one to put on another with Hotchkiss sway bars.
