Results 1 to 7 of 7
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Oil Drain Plug with attched washer.
    Couldn't find a subject on this one and thought I'd start a thread and maybe some of you can chime in....
    On my previous oil-change a few months ago I discovered some oil seepage around the oil pan/plug area and my indie asked if I bought any crushed washers (apparently the new guy wasn't aware there is already a washer on it) and I say no since our car seem to use these plugs with attached washers. He applied some glue around the old plug and it did stop the leak. Just did another oil-change yesterday and the glue seem to stop the leak pretty well. But since I've already bought a few of the same exact fit drain plugs from Audi (N-908-132-02). I just went ahead and replace it anyway. I work on my car a lot but one thing I don't do is oil-change for a few reasons....but that's another story for another day. So the question is how often do you guys replace this type of plug since there is no way of replacing the attached washer? I was surprised that it even held up this long. Here's the plug....
    Old plug is on the left, and the new one is on the right. Hard to make out the fault.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    Steel washers dont need to be replaced. It rarely gets crushed and gives out. With that being said- i never had to replace one untill my engine failed around 207k miles due sudden failure of the oil pump.
    Oct 09 2007
    Miele S7
    Wow, that lasted quite a long time. How often or what intervals do you change your oil? Like I mentioned, I found some seeping leak on mine at around 95K. Needless to say I just replace it.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    I replace them every oil change.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    I use an aftermarket magnetic plug, with new crush washers every change, but the oil service kits from FCP I use comes with new drain plug. So guessing it should be changed every oil change.
    Sent from my CPH2611 using Audizine Forum mobile app
    May 15 2019
    Bellevue, WA
    Quote Originally Posted by 80sGuy View Post
    5k-6k but it rarely makes up to 120hrs of usage. I used to drive about 60-70 miles a day minimum.
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    I just replaced mine after owning the cars for 10 years.
