Results 1 to 5 of 5
    Junior Member Two Rings
    Jun 24 2020
    Virginia beach va usa
    14 q5 3.0 tdi weirdness need some help
    Long time reader and I've learned alot from the forum. But, can't seem to find what I'm looking for. I'm getting a weird kinda roughly idle after car is warm. In gas terms, it feels like a misfire. I do have a code...208a it think. Def injector stuck open. Pulling that out today to investigate. Is there anything else I should look at while it's on the lift?
    May 20 2010
    You would probably feel at cold too, but good opportunity to check out the engine mounts.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Apr 13 2008
    2010 A4 Quattro P+, APR Stage I, 2015 Q5 TDI Prestige_2006 Jetta TDI, Malone Stage II
    florida
    You may want to inspect and clean the mountain of soot on the EGR valve, throttle body and intake manifold in the vicinity.
    -T99inFL-
    2015 Q5 TDI Prestige, Malone Stage II
    Jun 24 2020
    Thanks, was thinking of that. The codes are whats throwing me . It's on the list of maintance . The def codes are throwing me . I'm not familiar with diesel and how things work( I'm learning) I did check the def injector and it seemed clear. I know I'm checking the wiring/connections next. I'll post the codes.
    Jun 24 2020
    P208A - Reductant Pump
    Control Circuit/Open
    Permanent
    P208E - Reductant
    Injection Valve Stuck Closed
    Bank 7 Unit 7
