Results 1 to 4 of 4
    Jun 25 2023
    Reno,nv
    Mechanic question
    Purchased B7 RS4 in June. In August, oil leak appears. Estimated 3-4 weeks to repair timing cover, pcv and oil pan leaks. Mid-December and still without the car. Doesn’t seem that mechanic is working on car. Haven’t pain for anything. Thoughts on how to get mechanic to finish the job?
    Dec 05 2006
    So. Cal.
    How about going and picking the car up from said mechanic. Take it to Audi or do it yourself.
    Veteran Member Three Rings boostinfd's Avatar
    Sep 17 2009
    991.1 Turbo RS
    STL
    That job isn't that difficult... If they're not doing it, they're either overbooked or the guy working on that type of job is off for holidays. If you're mechanically inclined at all, you can do that. It's really not that hard. Good luck!
    991.1 Turbo RS
    Viper ACR
    F150 Raptor
    F82 M4 COMP
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Either pick up the car and take it to a different mechanic or perform the work yourself.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
