Results 1 to 16 of 16
    Sep 06 2020
    SC
    Techtonics downpipe for 6-speed manual
    $125 shipped. $286 new, but this wont have the gasket and bolts which you can get new separately. Bought in 2022. On the car for about 20,000 miles. Nothing wrong with it just replaced the downpipe and exhaust together with a milltek. Will ship at this price with shipping included as long as shipping is $40 or less.
    Veteran Member Four Rings prizmatik's Avatar
    Dec 15 2009
    Hell hole
    I’m guessing this won’t fit the 5 speed?
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by prizmatik View Post
    I believe the only difference is the mounting location on the transmission. Should be able to get a muffler shop to fab something up if needed. But can probably do w/o honestly.
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Sep 10 2021
    Pennsylvania
    I have some aftermarket kit on my car, and I broke the downpipe like a doofus. If prizmatik doesn't want it, I'll take it.
    Sep 06 2020
    SC
    I dont know the difference bt 5 and 6 speed version. I can email pictures of the one I have to anyone interested. Shoot me an email at [email protected]
    Veteran Member Three Rings Dr.B6Banter's Avatar
    Sep 26 2017
    B6 A4 1.8T, B8.5 SQ5
    NB, Canada
    I have a 5 speed downpipe in a car with a 02x 6 speed from a b7 and it fits fine. The mounting location to bolt the downpipe to the trans is the only difference as far as I can tell and I haven't been running that mount for the past 3 years without any issues for what its worth.
    B6 A4 1.8T Nottro 02X 6spd Conversion | GTRS | IE Forged Rods | Suspension/ Subframe Poly Bushings | 18z BBK Front & Back
    B8.5 SQ5 3.0t | JHM 207mm Crank Pulley | IE Dual Pulley Tune & ZF8 TCU Tune | CTS Test Pipes, Downpipes & HX | AWE Touring Exhaust
    Sep 06 2020
    SC
    Bump. Still available. This one mates up to a stock exhaust.
    May 04 2020
    PA
    Quote Originally Posted by StealthSC4 View Post
    Interested, can you send some pics of condition?
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Adaptor bracket for the down pipe mount from when I upgraded a five speed to a six speed.
    Sep 06 2020
    SC
    Yes please Email me at [email protected] and I will send pictures
    Dec 28 2008
    I've had a 6 spd system on my 5 speed for probably 10 years. Only issue was the mount like others have described. Made a plate and it's been rock solid for years without any issues
    Sep 06 2020
    SC
    Bump. Still available. Email me for pictures. Please post here so I can check my junk folder for your email.
    Established Member Two Rings Nate_Conner's Avatar
    Apr 08 2015
    Cincinnati Ohio
    Will this work on a 2.0T B7 with the 6 speed manual? after 165K my flex pipe finally ending cracking and im looking to replace it.
    Also, how does this connect to the rest of the exhaust downstream? will it need welded or is expanded for a slip fit/Vband?
    Jul 10 2015
    Colorado
    Email sent. Thanks.
    Sep 06 2020
    SC
    Quote Originally Posted by kwilson View Post
    Email sent. Thanks.
    Replied!
    To other question about 2.0T compatibility… I do not know. If you email me I will send you pictures and you can compare to your setup.
    Sep 06 2020
    SC
    Downpipe sold.
