Figured I throw this out there to see if anyone has come across this. I have this squeak on the front left side of the car. Here is what I’ve changed out so far. I have replaced the control arms , upper and lower , end links , sway bar bushings.
The issue comes when I’m at a stand still or slow speed with the suspension under load. I loosened up the sway bar bushings and the squeak stops. Tighten it back up and the noise returns . I’m pinpointing the noise to the subframe bracket. This seems to be where I’m hearing this noise. I loosened the motor mount nut and that didn’t have any effect. The end links aren’t making any noise either . Has anyone ever had an issue with the subframe bracket ?
