Results 1 to 13 of 13
    Junior Member One Ring
    Dec 31 2023
    Minnesota
    Unhappy EPC, Throttle Body, Misfire?
    Did a 3rd-4th hard pull on ko4, pull was fine, no bad feeling during but when I got off the highway, EPC light was on solid, and car was misfiring randomly, went into limp and wouldnt go past 2k rpm, no boost. Scanned and found P1558 - Throttle Valve Drive, P1545 - Throttle Valve control system, and random/multi cyl misfire. Was thinking issue with tb, so going to clean and reinstall but any ideas that could help would be great.
    Jan 29 2008
    Epc light Maby bad ecu
    Dec 31 2023
    Minnesota
    Can it really happen that fast? the car was running perfect before then, and was just going to get fresh tank of e85, then it just happened
    Jan 01 2018
    utah
    I had this issue, and my ecu box wasn't sealed correctly, and water got into my connector when I washed it. It took about 15 minutes of driving to start having issues.
    Sent from my SM-S928U using Audizine Forum mobile app
    Dec 31 2023
    Minnesota
    so would I just need a new ecu to fix that then?
    Jan 01 2018
    utah
    I pulled out my ecu and made sure all the connectors were dry. Then, resealed it.
    Dec 31 2023
    Minnesota
    Ok, cause i did notice small amount water in a puddle around driver seat and behind it, so I might have a blockage somewhere and water got into the ecu too.
    Jan 01 2018
    utah
    Possible.
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    I’ve had a bad throttle body and bad wiring on another car that did that. Usually I’d clear code and it be fine for alil or next day it would drive fine then randomly do it again.
    I’d check the wiring first at the connector since that’s quick and easy then see if there’s water in Ecu box like others have mentioned
    Dec 31 2023
    Minnesota
    Sounds good, ill update if anything changes or what happens, also would the issue with the throttle body cause multiple random misfires or is that just a completely random thing, at first I thought I just killed a coil pack before I saw the codes for throttle valve control
    Dec 31 2023
    Minnesota
    Looked hard for anything, the only thing i forgot was the plug to the tb, took 2 mins to replug it and the cars running as good as before
    Jan 01 2018
    utah
    Was it unplugged?
    Dec 31 2023
    Minnesota
    just slightly unplugged, don't know why but just pushed it back in a little to have it click together to the tb sensor and it was good.
