I recently replaced my trunk latch solenoid since the last one was slowly dying. Now my trunk latch 8E0827566 microswitch has gone bad. This part is the small rubber pad that sits under the trunk lip between the license plate lights. It seems in the B6, there is that part AND a microswitch that slides into it. For the life of me I cannot find the part number so I can order just the switch. Seems newer models has the switch built into the whole assembly.
Does anyone have a part number for this?
Edit: From looking at the aftermarket assemblies it looks like the switch is integrated into the panel. Short of pulling the trunk apart, I'm confused as to if there really is a replaceable switch in there.
Edit II: Answering my own question here but its part of the harness. 8E0971145. There is no plug on the microswitch. Seems the aftermarket combines it all into one assembly where your factory harness plugs into the entire trim piece w/ integrated microswitch.
