Good Afternoon, I have a 2013 Audi S6 and i’ve been experiencing some front end air bag problems. Most of the time the car has stayed up, but when i lift it it goes into tire change mode and releases all the air, when i try to raise it back up the rear goes up just fine, however the front just has a hissing sound, and i can get it to go up manually just by running air leak tests in OBDEleven and then it stays. I’ve also replaced the pressure relief valves and still, no dice. sometimes i can manually lift the car, then fill the bags through OBDeleven as well, what should i do?
