Results 1 to 23 of 23
    Oct 31 2022
    Prescott AZ
    Exhaust heat shield , embossed stainless
    I’m wondering if anyone has any insight on where I can get some thin embossed heat shielding so I can heat wrap the headers and down pipe ?
    I’ve spent a couple hours searching and it seems like there is a shortage.
    There is a place overseas that sells it but I’ve gotten no response.
    The other options I’ve come across seems like an architect construction supplier for kitchen backsplashes.
    So if anyone has any insight, that would be great!!
    May 20 2010
    Does it have to be stainless? https://www.amazon.com/Exhaust-Autom.../dp/B0DDT495J4
    Idk what you have or haven't done, but you may also want to consider ceramic coating the manifolds and downpipes to further reduce heat
    2016 A6 TDI Prestige - Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige / Ecru-Brown interior
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD
    2007 A4 2.0T quattro - Gone but not forgotten
    Oct 31 2022
    Prescott AZ
    It will be a dual layer. The first layer being a quarter inch thick, ceramic insulation fiber.
    Second layer being the welded stainless
    There is a ton of companies that sell the aluminum, but the stainless seems to be out of stock are hard to find
    I’m not sure but it seems like the aluminum might work. I have a sample piece coming, but I don’t think it’s as good as the stainless.
    Feb 23 2010
    Emmaus Pa
    I would avoid that unless you don't plan to drive in the rain often.
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Oct 31 2022
    Prescott AZ
    I’m thinking the headers should be fine tucked up where they are plus the method I will use should insulate the ceramic well
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    My fear was them getting oil on the insulation and catching fire. So I used some aluminum sheets but can’t remember where I got them from for the OP.
    Oct 31 2022
    Prescott AZ
    I’ve tried welding the aluminum to stainless and it will not work.
    So it will have to be the stainless embossed sheets.
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by Matthewest91 View Post
    Yea i didn’t weld mine. Just cut/bent to shape and made a hole to mount them with a bolt.
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    This stuff is widely used on the inside of aircraft engine nacelles. If you had access to a surplus/boneyard type place you could get enough to work with from just a single blanket. Hi-Temp is the primary supplier I've seen.
    The airplane standard is to have the sheets custom formed into a single piece. But for one-off type stuff, most of what I seen in automotive aftermarket is small pieces bonded together. Capacitance welding is the way to go for this, but if you don't have access to one of those you could probably get away with clamps/safety wire/fasteners.
    Oct 31 2022
    Prescott AZ
    This is great stuff thanks man!!
    I want awareness of a junkyard for planes until you said something.
    I do have Davis-Monthan Air Force Base, AZ , which is definitely I trip to see in person but doubt they have junkyard access.
    I’ll definitely check that link out.
    And yes I have a capacitor welder otw, hopefully it will be better than my first method.
    Oct 31 2022
    Prescott AZ
    My first attempt was a failure.
    Second attempt was a little bit better.
    Still have not found the right stuff.
    Feb 05 2007
    Portland, OR
    Have you tried reaching out to manufacturer or tuning company like Canadian Auto Performance and asked what they use for their stuff?
    Couldn’t hurt to see if they’ll lend you a helping hand.
    Oct 31 2022
    Prescott AZ
    So far, we reached out to three companies and haven’t gotten a response from a single one yet
    Veteran Member Three Rings xRenesis's Avatar
    Jan 14 2015
    South Dakota
    Don't search for embossed, just stainless exhaust insulation
    https://www.heatshieldproducts.com/inferno-shield
    2005.5 A4 B7 - 2.7t K04 - DTM/S4 OEM+ (My B7 Rear BBK)
    2014 Q5 B8.5 - 3.0t (My B8/B8.5 Rear BBK)
    ig 1red_b7
    Oct 31 2022
    Prescott AZ
    I need just the foil.
    That stuff will be a pain to weld with the insulation on the back
    Jan 14 2015
    South Dakota
    The point of it is the insulation. You won't have much of an air gap with just the foil to the exhaust/turbo. The stuff like CAP, is insulated and sheets welded to each other, which you can do by cleaning the insulation off the edges and welding it.
    ig 1red_b7
    Oct 31 2022
    Prescott AZ
    I think I want to try .002 material.
    Was having a hard time shaping the meat
    Oct 31 2022
    Prescott AZ
    Prototype
    Feb 05 2007
    Portland, OR
    Jan 01 2018
    utah
    How did you weld it?
    Sent from my SM-S928U using Audizine Forum mobile app
    May 20 2010
    Sweet!
    Oct 31 2022
    Prescott AZ
    This was not an easy or cheap thing to figure out. Probably would have been cheaper to just sent it out lol
    The material is not cheap either.
    Which is why I posted to find material.
    Us foils quoted me 600$ plus 80 shipping
    For a 36”x40” piece of embossed stainless steel
    Still looking for better options.
    Junior Member Two Rings
    Dec 01 2021
    Plymouth
    Looks smart, how much did the welder and insulation cost roughly? I'd like to do something similar with my manifolds and turbo hot sides, did you follow a guide or just wing it?
