Results 1 to 12 of 12
    Junior Member Two Rings
    Sep 04 2018
    Atlanta, GA
    S6 exhaust options? Too loud currently
    Hi all,
    My 2013 S6 came with catless downpipes and some kind of custom exhaust with an X-pipe and no resonators or mufflers. Obviously it's very loud.
    Does anyone have a good setup that would be relatively cheap/easy to get an exhaust shop to do?
    Current:
    2013 S6 DS1 tuned: SRM +4 turbos, downpipes, etc
    1995 UrS6 Avant: Euro bumpers, forged internals, EFR6758, KW coilovers, ec
    997 Carrera
    Past: UrS6 x4, RS6 manual swapped, B8.5 S5, other dumb cars
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Since it's already a custom set-up, maybe just taking it to an exhaust shop to put resonators and mufflers back on? That would be the cheapest/easiest way vs catback. Resonators are useful to reducing drone in the car. Both would aide in making it quieter
    There is no need for an X-pipe on a turbo car - typically done on NA cars for scavenging exhaust gas pulsing, which you don't need to worry about on turbo cars (straight pipe is proven best for turbo cars) . Only purpose on turbo cars is to change the sound.
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Established Member Two Rings STXA7's Avatar
    May 24 2024
    Shelves full of crap
    South Texas
    Quote Originally Posted by benznotmercedes View Post
    Hi all,
    Since you’re running a v8 you should consider the vibrant ultra quiet resonators in the factory location ( under driver seat area ). The regular shape bottle resonator likely won’t be enough. Do you still have your original quad tip rear mufflers? If not you can probably get some used ones from eBay and regain your valve control that came with your car from factory. I wouldn’t delete the xpipe unless you’re going to replace it with a dual in dual out resonator. There are many brands to choose from just be sure it’s a packed resonator. You could technically weld in any kind of resonator right before your exhaust tips if you don’t want to buy OEM used s6 mufflers and or don’t care about regaining the ability to switch between quiet mode and loud mode. It wouldn’t be crazy to get a different shape / brand of resonators for the exhaust tips if you do pick the vibrant ultra quiets for downpipes.
    I am a 034 nutswinger
    Disclaimer: I am not sponsored or affiliated with 034 motorsport, just one of many happy customers.
    Apr 22 2013
    Brooklyn NY & Cherry Hill NJ
    ECS Tuning (Wild shipping prices) sells exhaust mufflers. But that's costly. The best bet is sport OEM mufflers and reintroducing the muffler valves back into the equation. Cold Starts will continue to be brutal but should tone down the sound by a lot.
    Stock mufflers work well for killing exhaust volume.
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    just add 2 mufflers and be done
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Established Member Two Rings sandjunky's Avatar
    Sep 12 2016
    Push mower and RC cars
    Lincoln/ca
    I just had the JHM three-inch mid-pipe back valved system installed and OMG is it amazing!! It has a sound that is like nothing I've heard before and isn't loud at all (very deep tones). The kit is a direct bolt-on and comes with everything you'll need to install in your garage.
    https://www.youtube.com/watch?v=yg7U...SOYSd_g2WnNVTg
    2011 S5 M/6 - sold
    2016 S7 - APR TCU/ECU, CETE, Shiny Things and more coming
    2017 Q7 Prestige - Dream crusher hauler
    May 24 2024
    South Texas
    Quote Originally Posted by SpongeM View Post
    factory pair can be had for under 500 used on fleabay i second your idea
    Sep 12 2016
    Lincoln/ca
    I have my old factory sport mufflers if that's something you'd be interested in.
    2011 S5 M/6 - sold
    Veteran Member Three Rings MTV10's Avatar
    Apr 29 2020
    Montreal
    Add mufflers at the back and you'll be all set
    2018 /S6 | Mythos Black / Arras Red | Stage II ECU | APR TCU | ARM Downpipes | AWE Touring Exhaust | SRM Intakes | CETE Lowering Module | 034M DSG Mount Insert | HRE P43SC
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Quote Originally Posted by sandjunky View Post
    Glad you like it
    Established Member Two Rings srb_brah's Avatar
    Sep 27 2024
    St. John, Indiana
    Borla Catback exhaust >>>>
    2017 S6 Premium Plus - Ibis White | Arras Red & Black Optics | Stage 1 IE | Borla Catback Exhaust | RocEuro CAI | 31K Miles
    Sep 04 2018
    Atlanta, GA
    Sorry, I forgot to update this. I added some Vibrant Ultra Quiet resonators and it definitely toned the sound down some.
    Current:
    997 Carrera
