I installed a new HFC a couple weeks ago and the car is throwing P0234 for overboost (see below). I was flashed JHM Stage 1 beforehand and had no such code until I switched to stock while I was waiting on the new Stage 2 tune. (refer to this thread: https://www.audizine.com/forum/showt...ble-for-tuning)
What's throwing me for a loop is the fact that this code is PENDING (no CEL) and kicks the car into limp mode anyways. I've isolated it a bit over the last week or so: It only throws the code when in a higher gear and when I start at a low RPM. I was on the highway earlier and did a pull in 5th gear to keep up with traffic and ~3kRPM I lost all boost. Pulled off to the next exit, pulled out my cheap scanner to clear codes and not 3 mins later I was able to get the car into limp mode again, same situation. No idea if this is relevant but I also noticed a SIGNIFICANT amount of turbo flutter as soon as I crossed the 3k mark, then would go into limp mode. Something is clearly not right here.
A few things I have yet to try (but plan to w/ parts on the way):
- Replace N75, never replaced after owning for 7 years
- Clean MAF sensor (I've been told this could be the problem, it's been years since last cleaned. Source: https://www.audizine.com/forum/showt...-going-Stage-1)
- New spark plugs, cause it's about that time again.
Any prior experience with this would be appreciated! Thanks in advance.
