Hi All, very first post ever. I have a '23 RS3 w/ around 13k miles. Dont plan on putting anymore miles on till I do some engine upgrades. I took it out recently and an engine light had appeared.
Follow DTC's appeared: (scanned w/ topdon phoenix lite 2)
01 Engine Electronics: P003300 Turbocharger Bypass Valve Control Circuit, High
15 Airbag: B101C07 Driver Seat Belt Switch - Mechanical Malfunction
17 Instrument Cluster: B201100 Incorrect Basic Setting
19 Data Bus OBD Interface: B1902F1 NV-Energy Management - Alarm Triggered
19 Data Bus OBD Interface: U105000 Battery Monitoring Control Module - No Communication
19 Data Bus OBD Interface: U123100 Ethernet Databus Branch 6 - No Communication
5F Information Electronics 1: U15CA00 Secure Control Modules, Internal Communication - Not Available
75 Emergency Call Module And Communication Unit: B1915F1 Online Services - Function Temporarily Restricted Due to Battery Budget
With all of these codes popping up there are many concerns. My main concern is the Turbocharger Bypass Valve Control Circuit being high. Looked it up and haven't found much, except something could be wrong with the seal on the diverter valve. Or something could be wrong with the fuse or electrical lines. (which I highly doubt especially w/ 13k miles) My assumption is that it has to do with the seal on the diverter valve. So I write to this forum to see if anyone else has experienced any of these codes and if there are some that I should be worrying about more than the others. ETC. Car runs fine, but engine light is on due to the first code.
If anyone could help or give advice that would be greatly appreciated!
