I have a 2012 Audi Q5 that I'm in the process of tearing down to replace the pistons/rings. I was hoping to be able to remove the cylinder head without removing the cam cover. I was able to slide the "sleeves" on the exhaust shaft to get access to all the head bolts. All the bolts are loose, but on the exhaust cam side, I'm only able to get the front bolt out completely so far. I've been attempting to get the remaining 4 bolts up and out of the cam cover access holes with a magnet, but I'm running into an interference where the top edge of the bolt (just barely) hits the exhaust camshaft; there doesn't seem to be enough "wiggle room" in order for the bolt head to clear the camshaft. Not sure if removing the cam bridge might allow for some play on the exhaust camshaft to allow removal of the bolts. I really don't want to take the cam cover off unless I have to. Any advice would be appreciated.
